Version Note: This is the ARF+ version for pilots who wish to install their own power system. All primary electronics including servos and landing gear retracts come pre-installed, just add your own power system (EDF, motor, and ESC) to begin flying.
The 90mm Zeus is the latest sport jet offering from Freewing. Featuring a sporty and highly aerodynamic design, the Zeus 90mm is Freewing model,s fastest sport jet yet, reaching speeds of 130 miles per hour (210 kmh) in level flight. Additionally, the blue, grey and white livery offers an attractive, bold presence that can be seen easily in the skies. Impressively designed, the wings are glue and screw-free utilizing a quick release wing lock mechanism that makes installing and removing the wings a simple and quick experience.
Each control surface is managed by a 17 gram metal gear servo for quality and confidence. Offered in 6S, 8S and ARF PLUS, the Zeus promises to deliver the most powerful thrust-to-weight ratio of all the Freewing sport jets before it. Take to the skies and experience the incredible thrill and neck-turning speed of the Zeus!
Feel The Need For Speed
The Freewing Zeus 90mm EDF is the fastest sport jet developed by Freewing to date. At 130mph straight-line speed out of the box (6S PNP), the Zeus is sure to quench your thirst for acceleration.
Quick-Install & Release Wings
The Zeus 90mm EDF features a screwless quick release wing design that makes field assembly and disassembly a breeze.
Slow Your Roll
The Zeus includes a thrust-reversing ESC (PNP versions) enabling a brake-like effect, effectively reducing your roll out on landings. This is especially useful on shorter, paved runways.
Grass Friendly
The Zeus 90mm EDF sport jet comes with CNC-machined struts with a trailing link design that can handle most reasonably-mowed grass fields with ease.
Navigation and Position Lights
The Zeus features daylight-bright LED lights on the wing tips, top and bottom of the fuselage, as well as a landing light that is mounted on the nose gear strut.
Vivid Color Scheme
The color scheme on the Zeus is bright and vivid, providing great visibility in all types of situations and conditions.
Great Sound and Power
We recommend adding the new 12-blade 90mm EDF unit with a powerful 3668-1960Kv inrunner motor for high end EDF jet performance to your ARF PLUS.
Full Landing Gear Doors
The Zeus has fully sequenced gear doors, including inner main gear doors for lower drag and better sport jet performance.
Features:
Sleek, aerodynamic design for incredible sport jet performance
Quick release main wings provide a simple and easy process for installing and removing the wings
CNC-machined landing gear struts with trailing link design for better grass-field operations
Daylight-bright LED lights located on the wing tips, top and bottom of the fuselage and a landing light on the nose gear strut
(7) 17g, digital, metal gear metal gear servos for all control surfaces
(2) 9g, digital, hybrid metal gear servos for nose gear steering and nose gear doors
Fully sequenced gear doors, including inner main gear doors for lower drag and better performance
Nylon hinges on all control surfaces
Package Includes:
Freewing Zeus 90mm EDF Sport Jet - ARF PLUS
Electronic retractable landing gear (installed)
Servos, LED Lights (installed)
