Futaba SBUS RC protocol reverse engineered
3689451681?profile=original
From Hackaday:
In the world of model aircraft, Fubata’s SBUS system is a big deal. Instead of having one servo per channel, the SBUS system allows for 16 proportional controls and two digital channels for each receiver. Basically, if you’re building an awesome plane with retracts on the landing gear and bomb bay doors, this is what you want to use. [Michael] wanted to use a few SBUS servos for a project he’s working on, so of course he had to reverse engineer this proprietary protocol.
Each SBUS servo operates over a single 100kbps serial connection with a few interesting twists: the signal is transmitted as big endian, but the individual bytes are little endian, something [Michael] figured out after stumbling across this month old mbed post. [Michael] used a serial library written by [fat16lib] and was able to change the parity and stop bits along with a simple hex inverter. Everything worked perfectly when the servo was connected to a an Arduino Mini.
Even though the SBUS system requires special Fubata servos, we can easily see how useful [Michael]‘s work would be to outrageously complex robots or cnc machines. Check out the video after the break for a quick demo of [Michael]‘s breadboard controlling one of these SBUS servos.
  • This is awesome!  I was hoping someone was able to make this happen!  So many uses!
    "Even though the SBUS system requires special Fubata servos,"
    I agree that for the most part you are limited to S-Bus servos, but you then combine it with one of these...
    3692388286?profile=original
    and now we can use all of our current favorite servos. Will be good to see the use of S-bus grow! It has the potential to drastically clean up the wiring on vehicles and simplify installations and additions.
