Hi all! I've been trying to come up with a way to cut foam sheets for some of my drone projects. I had to balance temperature and speed. I may have thought of something that was discovered years ago but I still find it postworthy. I just setup my hotwire cutter on and angle. It gave me a nice smooth cut without jittermarks. The speed is set by the angle of the board. I set the temperature by adjusting the width of the leads. For a power source i'm using an old lipo battery charger. Here are some results of just test foam.
Cool idea. Are you only able to cut straight lines or have you been able to make any wings as well?
