It's designed to support Pixhawk, which you can see installed here:
From the new Kickstarter listing:
Ritewing Drak - The Next Generation RC Aircraft / Drone
by Chris Klick
The Drak is the first forward swept RC aircraft that combines extreme durability with unmatched stability & energy efficient flight.
About The Drak Project
The Ritewing Drak is a visually stunning and durable remote control (RC) airplane design that is capable of extremely stable and energy efficient flight. This aircraft was designed as a high performance platform for any use: the typical RC enthusiast, first-person-view (FPV), or unmanned aerial vehicle (UAV). When designing the Drak, we had one mission in mind: to give the average person the ability to capture quality video and photographs or scientific data over an extended geographical area from an unmanned aircraft. The Ritewing Drak has sufficient cargo space and weight bearing capacity to accommodate all of the electronics and sensors that would be needed for any application.
Introducing the DrakQuad-copters are hot items that boast the ability to capture aerial images, but the Ritewing Drak goes where quad-copters simply can’t. The Drak can cruise expansive areas over an extended period of time to capture video, still photography, or other data with ease. A quad copter simply cannot match the distance and duration parameters of the Drak’s fixed wing platform. The reason is simple: the fixed wing platform actually flies through the air through the principles of lift from the shape of the wing. This allows the Drak to stay in the air with minimal power consumption. A quad copter can only support its weight as long as it has power to its motors.
Go Beyond the Reach of Quad CoptersRitewing’s goal is to get a Drak into the hands of every RC & FPV Hobbyist or anyone with need for the capabilities that this aircraft possesses. The Drak can enable anyone to capture amazing video and photos from the sky. It's never been easier to capture spectacular aerial images over vast expanses that provide a new perspective that had previously been unseen.
Reach Uncharted TerritoryThe Key Features of the Ritewing Drak
1. Innovative forward swept wing design to avoid low speed stalling
2. Rock solid stability in flight for optimum video and picture quality
3. Lightweight and durable air frame manufactured from EPP (expanded polypropylene)
4. Proprietary bay system offers maximum payload capacity and adjustability for balancing
5. Extended flight times possible depending on configuration and flight habits
6. Easy to assemble kits, Almost Ready to Fly (ARF), or Ready to Fly (RTF) available
7. High quality materials and components
8. Upgradable and expandable
9. Designed to break down for easy transport and storage
10.All parts are easily repairable or replaceable
11.Able to go where quad copters cannot go
12. Easy to launch by hand
Drak Project Background
Chris Klick is the creator of and the driving force behind Ritewing. Chris has very humble beginnings as an RC flight enthusiast, but even at that time, he was focused on finding the best RC aircraft possible to feed his appetite for the hobby. Chris was obsessed with finding the best high performance aircraft that combined durability, speed, and exceptional flight characteristics. After a couple of years of searching for the best the hobby industry had to offer, Chris started his own research and development efforts to create the type of aircraft that no one else seemed to be developing. Through Chris’ R&D efforts, Ritewing established a presence in the RC aircraft market, and developed a following of dedicated customers who knew that buying a Ritewing meant getting a product that would perform far better than anything else on the market.
Chris Klick of RitewingAfter his early successes cutting models like the Ritewing Demon and Ritewing Zephyr on CNC hot wire foam cutting machines, Chris knew the key to bringing his work to more people was to take advantage of mass scale manufacturing technology. After Chris created the concept of the Ritewing Zephyr II, he set out to find a manufacturing partner.In his own back yard, Chris found an established foam molding company that was eager to help him bring the Zephyr II to life as a molded foam product. After its release, the foam molding manufacturing process helped make the Zephyr II the best selling Ritewing of all time.
The Zephyr II flying wing was an incredible product that found its way very quickly crossing over from the typical line-of-sight RC hobby world into the more advanced First Person View (FPV) hobby and the Unmanned Aerial Vehicle (UAV) markets. Next, Chris developed the Spade line of aircraft: the 70”, the 47”, and the yet to be released 52” version. Ritewing went back to the same manufacturing partner to have the 70” and 47” Spades brought to life. Now, Ritewing wants to share Chris’ next innovative aircraft design, the Ritewing Drak, with the world through this Kickstarter campaign.
The Problem:
Currently, each Ritewing Drak is a hot wire cut prototype taking 60 hours of labor to create and make flight ready. This amount of labor makes the cost to produce very high. To make the Drak available to the general public at an affordable price, molding the airframe in EPP is critical. The EPP molds take up to 3 months to produce and are very expensive. As expensive as the creation of the mold is, we must also pay for the first production run of a minimum order quantity from the molding facility. Since the mold does not stay in the machine permanently, the facility requires that a minimum number of parts be produced to make it worthwhile for them. The mold must be installed and configured to run every time a production run is scheduled.
The obvious benefit of the mold process is the ability to produce a large number of precision molded air frames in just a couple of days, instead of hot wire cutting just a handful in the same time frame. The successful funding of this Kickstarter campaign will enable us to mold the aircraft and offer them for an affordable price.
Drak Technology Details
1. Innovative Design
- Dissembles into three main pieces for easy transport and storage
- Forward swept wing style to avoid tip stalling at low speeds
- Rear mounted electric motor and propeller
- No landing gear required
- Built-in camera and gear mounts
- Travel and storage case available
The Drak is Portable2. Easy to fly and simple to maintain
- No messy fuel
- Uses high capacity LiPo battery packs
- Pilot from your existing radio controller
- Can be flown with any flight controller or auto pilot
- Control from any computer, tablet or game controller in conjunction with the flight controller you choose
- Simple, quick, and inexpensive to maintain and repair
- The cargo bays make balancing the aircraft a breeze
The Drak is Lightweight3. Lightweight with maximum payload
- Flight and control is stable and accurate for optimal photographic results
- Manufactured from durable EPP
- Our bay system provides the payload capacity for all gear and multiple cameras
- Weighs in at around 6 pounds when ready to fly
- Carries an action camera like the GoPro or Mobius with separate mounts
Multiple Camera Configurations Possible4. Advanced capabilities possible using a flight controller of your choice
- Auto take-off and landing
- Integrated onboard autopilot flight planning
- Set and fly waypoints using GPS satellite technology
- Fly in aided mode
- Return to home (RTH) capabilities
- Load/Save and repeat/replay flight missions
- Real-time flight data
Typical Ground Station Control Software5. Extended Flight Times
- Wings designed to make extended flight times possible
- Up to 1 hour flights (fully loaded with camera)
- Exclusive propellers engineered and optimized especially for rear motor aircraft
- High output LiPo battery technology
- Energy efficient electric motor
6. High quality materials and components
- ·Professional grade build quality and workmanship
- ·Extra durable and robust airframe
- ·Carbon fiber and fiberglass sparring system
- ·Highest quality components
- ·Custom CNC aluminum motor mount system
- ·Designed in the USA
Hello to everybody!!! I just bought a mini drak wing from Chris with extra tail boom. Does anybody set up this wing with apm or pixhawk? I need the pid table and the parameter's file. I have never set up airplane before, only multocopters. I will appreciate your help. mini%20drak.jpg
ha that sounds cool - and bird of prey is exactly what i thought when I saw it... flys even better than it looks and I have tried an auto launch by just holding it not even throwing and it just takes off... so easy
If I owned one I think I'd paint it a nice dark green and black. Then I would send it back in time to save some whales (and Spock too). Darn it. I miss "Spock" already. Going to watch some Wrath of Khan now.
Sweet looking air frame.
Just wanted to re-share this kickstarter campaign for a plane that I have flown on pixhawk, both FPV and line of sight.
This plane is forward swept wing so has amazing slow flight ability for easy landing, is very stable, tons of room for cameras, transmitters, pixhawk and peripherals on a tray in the center section. Perfect to drop ArduPlane into.
The material advertised that it will be made from in the Kickstarter is a very durable EPP and this will take a ton of abuse.
Also this is a small american business, who better to support !!
No sens to read more...Self PR company started again..And again...
I really like the landscape photos. It would take you days & days and much exhaustion to just get to that area.
