Hi guys,
We would like to share with you very simple find we did during our operations. Making reusable Ground Control Points (GCPs) for aerial photography and photogrammetry.
We spend a lot of time testing and tuning our Universal Ground Control Software U[g]CS in a real world scenarios.
For aerial photography and photogrammetry you can rely on modern software like Pix4D, Acute 3D and other to produce good results without ground control points. If good is not enough and accurate 3D model or digital map needs to be rendered you always need GCPs.
We started from “classic” crosses made from painted plates of cardboard, wood and plastic, but they proved not to be practical in every situation and all weather conditions we encountered.
And finally we found that best material for small GCPs is simple ceramic tiles:
For each GCP you need 2 black and 2 white tiles with mat surface. Glossy has reflections and does not work well.
They are absolutely water (rain/snow), wind and mud resistant. Can be easily transported in car and reused almost forever. Until human error takes its toll and you drop them on rocks or hit hard against a car.
Tiles with 40X40 cm size proved good for making shots from up to 100 meters.
This is a shot taken from approx. 50 meter altitude with GoPro:
Zoomed in part of the frame above:
Good luck and safe flights,
UgCS team
Hi, as I remember we used all settings by default.
Hi again, do you have any advice for what settings to use in Pix4d to get it to resolve the wires into the point cloud? I have collected imagery now and am about to process it. I made sure to fly as per your advice above and the wires show up clearly in the imagery.
Awesome! Thanks for your help!
You should fly back and forth along a line on both sides of it.
An important point - you need to get a good overlap (~80%) of images on the conductor's level. For that you need to know approximate conductor's altitude.
Also pixel size on conductor's level should be at least as half of conductor diameter.
To simplify calculations you can use Photogrammetry tool (available only in paid versions of UgCS). Draw any area, specify GSD = conductor diameter/2, forward overlapping = 80%, side overlapping = 70%. Select appropriate camera action (trigger by distance or trigger by time).
UgCS will calculate altitude, distance between survey lines and time or distance between shots.
Next you can manually draw your route along powerline. Use calculated distance between survey lines as distance between your back and forth flights, add conductor's altitude to calculated altitude and use calculated distance or time between shots.
Last important step - you MUST check minimum distance from drone to conductors. It depends on line voltage.
And NEVER fly under conductors.
Good luck :)
Good luck :)
Hi, What flight path / flightplan do you recommend to successfully capture the transmission line wires as shown in the first image?
Yes. We used Pix4D Discovery - free version.
Ok, we will share our Excel macros and experience.
Thats very interesting, we are working on a similar project in my country but we must do thermography to each tower and create and autonomous inspection line. Maybe we could share experiencies and stay in touch.
thanks
And important point - we used only automatic mode and planned routes in UgCS (of course :-). In manual mode there is a lot of chaotic movements and it seems that for software too hard merge separate pictures.
Now we are working on macros for Excel which will produce flight plan for electricity lines reconstruction/diagnostics based on tower coordinates and types. We will publish it here. Our macros will produce flight plan in UgCS format, but it will be possible to modify it for any planning software.
1
2
of 2 Next
