Choosing a heavy lift FPV drone manufacturer involves more than comparing payload ratings. Buyers also need to consider flight endurance, airframe design, payload integration, component compatibility, and the supplier's ability to customize and deliver a complete aircraft.
Several manufacturers now offer configurable heavy lift FPV platforms for commercial and industrial projects. However, their product ranges, engineering capabilities, and business models differ. This guide reviews five manufacturers and explains what buyers should evaluate before choosing a supplier.
1. Leading Heavy Lift FPV Drone Manufacturers
The following companies offer heavy lift FPV platforms, customized configurations, or project-based drone development.
1. SkyVolt FPV
Website: https://www.skyvoltfpv.com/
SkyVolt FPV is a Shenzhen-based manufacturer offering professional FPV systems, including long-range and heavy lift platforms.
Its product range includes 13-inch and 15-inch heavy lift drones, with the company advertising payload capacities of up to 8 kg. It also offers OEM/ODM services, covering airframes, flight controllers, electronic speed controllers, and other components.
Best suited for: B2B buyers looking for configurable FPV platforms, private-label production, and component-level customization.
2. ArcoSky
Website: https://www.arcosky.com/
ArcoSky supplies FPV drones and components, with platforms ranging from 10 to 22 inches. Its larger models target applications requiring higher payload capacity and longer flight distances.
The company offers different frame, motor, and propeller configurations, along with camera and video transmission options. OEM/ODM arrangements and bulk supply are also available.
Best suited for: Buyers comparing different airframe sizes and looking for configurable heavy lift platforms or wholesale supply.
3. Feiya Innovation
Website: https://feiyainnovation.com/
Feiya Innovation manufactures several types of UAVs, including industrial drones and FPV platforms.
Its FPV range includes 7-inch, 10-inch, 11-inch, 13-inch, and 15-inch models. Some configurations use multiple motors or propellers to support different payload requirements.
The company also provides customized UAV solutions and OEM services, making it an option for buyers who need more than a standard FPV configuration.
Best suited for: Projects requiring different UAV configurations, industrial platforms, or customized aircraft development.
4. UAV3
Website: https://uav3.com/fpv-drone-c249693/
UAV3 supplies FPV drones for racing, long-range flight, and heavy-duty applications.
Its published product range includes 10-, 13-, and 15-inch platforms. The company also lists heavy lift FPV configurations with advertised payload capacities of 4–8 kg, alongside a custom cargo drone option.
Available customization includes motors, flight controllers, cameras, video transmission systems, and payload configurations. OEM and ODM services are offered for project buyers and distributors.
Best suited for: Buyers looking for configurable FPV platforms with different payload requirements and project-based customization.
5. SkyLark System
Website: https://skylarksystem.com/
SkyLark System offers a series of heavy lift FPV drones, including the SL-X07, SL-X10, SL-X13, and SL-X15.
The platforms cover different payload classes, with the larger models designed for heavier equipment. The company also offers customization of airframes, flight controllers, propulsion components, cameras, and video transmission systems.
Its product and service portfolio includes visible-light and thermal imaging integration, as well as digital fiber-optic video transmission.
Best suited for: Buyers requiring customized FPV aircraft, payload integration, and coordinated drone component solutions.
Note: Payload figures and product capabilities in this section are based on manufacturers' published information, not independent comparative testing. Buyers should request test data for their intended configurations.
2. How to Compare Heavy Lift FPV Drone Manufacturers
Not every supplier offering a heavy lift drone has the same engineering or production capabilities. Before requesting a quotation, buyers should compare several areas.
| Evaluation Area | What to Check |
| Payload capacity | Rated payload, maximum payload, and performance under actual load |
| Flight endurance | Flight time with the intended payload and battery |
| Customization | Frame dimensions, mounting structures, motors, and power systems |
| Payload integration | Camera, thermal sensor, gimbal, and communication interfaces |
| Engineering | Prototype development, testing, and technical documentation |
| Production | Sample orders, batch consistency, and repeat production |
| After-sales support | Spare parts, troubleshooting, and technical assistance |
A manufacturer advertising a 10 kg maximum payload does not necessarily offer 10 kg as a practical working load. The maximum figure may represent a short-duration test under specific conditions.
A more useful comparison is the rated payload and corresponding flight time under a clearly defined configuration.
3. What Should Buyers Consider Before Choosing a Supplier?
Define the Complete Payload
Start by calculating the weight of the entire equipment package, not just the main camera or sensor.
Include mounting brackets, cables, power converters, communication modules, and other accessories. These components can significantly increase the final payload.
Also consider the equipment's dimensions and center of gravity, as these affect airframe design and flight stability.
Check Customization and Integration Capabilities
A suitable manufacturer should be able to explain how the aircraft will accommodate the intended payload.
For example, integrating a thermal camera may require more than a suitable mounting position. Power supply, video output, communication interfaces, vibration isolation, and compatibility with the onboard flight system must also be considered.
Ask whether the supplier can provide a complete integration solution or only individual components.
Request Actual Flight Test Data
Ask for flight time under the expected payload rather than relying on no-load endurance figures.
Useful information includes:
Aircraft takeoff weight and payload weight.
Battery capacity and configuration.
Flight time under representative conditions.
Motor and ESC operating conditions.
Stability and vibration test results.
Where possible, request a demonstration or prototype test using the actual equipment.
Evaluate Long-Term Supply and Technical Support
For commercial projects, the first aircraft is only part of the purchasing decision.
Check whether the manufacturer can maintain component availability, reproduce the same configuration across multiple units, provide replacement parts, and support future modifications.
This is particularly important for integrators and companies planning to deploy multiple aircraft.
4. Questions to Ask Before Ordering
Before committing to a supplier, consider asking:
What is the recommended payload capacity, and how does flight time change under that load?
Can the aircraft be customized for specific equipment dimensions and mounting requirements?
Can you integrate third-party cameras, thermal sensors, and communication systems?
Do you provide prototype development and flight testing?
Can you provide test reports for the proposed configuration?
What are the minimum order quantity, production lead time, and spare parts arrangements?
The answers can help distinguish a supplier that simply assembles standard components from one capable of delivering a complete customized aircraft.
These are my thoughts on choosing a heavy lift FPV drone manufacturer. Ultimately, the right choice depends on the project's payload requirements, customization needs, and the manufacturer's ability to deliver a reliable aircraft.
What do you think? Do you have a different perspective or experience with these manufacturers? I'd be interested to hear your thoughts and continue the discussion.
