T3
Helical turn controls
3689655567?profile=originalFirst of all, thanks to Peter Hollands, who produced the above picture of a helical flight trajectory from one of his HILSIM test flights of the latest version of fixed wing flight controls for the open source MatrixPilot project, also known as the UAVDevBoard. For the last year or so, Peter has been helping me develop a "helical turn control" for MatrixPilot, starting last summer when I decided to start over on the MatrixPilot fixed wing flight controls, using basic principles. One goal of the new controls was to be able to fly an arbitrary helical trajectory. Peter had some fun producing the above trajectory using XPlane-10 and HILSIM, running the new controls.
The theory of helical turn controls is described in the following three attached documents:
The first document, HelicalTurnPart1Conditions.pdf, describes the conditions that need to be satisfied to achieve a coordinated helical turn.
The second document, HelicalTurnPart2Controls.pdf, describes a simple controller, relying mainly on feedforward and proportional feedback, for satisfying the turn conditions, using matrix-vector computations.
The third document, HelicalTurnPart3AoA.pdf, describes a method for accounting for angle of attack and variation of elevator trim with wing loading and airspeed. Required model parameters are computed automatically from flight data using a program that Peter Hollands wrote.
Helical turn controls has been thoroughly flight tested for over a year, and has been found to perform quite well, including the following advantages, for example:
  1. Tight, smooth, aggressive turns in both normal and inverted flight. For an airplane with ailerons, the controls can put the aircraft into a turn in less than 1/4 second, and can provide stable control with a turn rate up to the limits of the ranges of the gyros and accelerometers.
  2. Level flight during a 180 degree roll over from normal to inverted flight.
  3. Easier low speed hand launches because the controls automatically adjust angle of attack and elevator trim for changing airspeed.
  4. Projection of earth frame pitch control onto body frame control surfaces, so pitch control is maintained in any orientation, including knife edge, or during a slow roll.
  5. Elimination of the need for integral feedback. Using helical turn control, a combination of feedforward and proportional feedback performs better than conventional PID feedback control. This simplifies the selection of gains. The controls work well over a wide range of proportional feedback gain settings.
Here are a few pictures from recent actual flight testing with my EasyStar. First, a few circuits around a rectangle in waypoint mode are shown. Please note that some of the flight segments and turns were flown inverted:
3689655606?profile=original
Next, a close up of the tracks through waypoint 4. Note that there are many tracks and they are all within a few feet of the waypoint, in all three directions:
3689655593?profile=original
Finally, a view of a 180 degree roll over from normal to inverted. Note that the controls automatically account for the reversal in sign of the wing loading and adjust the angle of attack and elevator trim to maintain level flight. You can see that the plane quickly pitches up a bit once it becomes inverted:
3689655526?profile=original
By the way, one problem I ran into during inverted flight was that the EM506 GPS that I was using stopped working when it was pointed toward the ground. A friend of mine at our flying field, Robert Pixley, suggested a solution that I did not think would work, but it did: mount the GPS vertically instead of horizontally:
3689655620?profile=original
What I found was that with a horizontally mounted GPS, there were typically 10 or 11 satellites in view during normal flight, and at most 4 in view during inverted flight. With the vertical mount, there were 8 or 9 satellites in view all of the time.
Finally, a thanks to all of the MatrixPilot developers and users who helped me with this, and a few links to those of you who might be interested in the MatrixPilot project:
MatrixPilot project home page.
UAVDevboard available from SparkFun.
Helical turn controls firmware.
Best regards,
Bill Premerlani
