Happy new year folks!
DIYdrones hardware development team needs some help, if you think you can contribute in something please PM, our requirements are:
-Any microcontroller capable to handle a little web server can be used.
-The hardware must have WiFi access (behave as an access point).
-The hardware must have SD card slot (where you can store html files).
-Must be cheap (< $100).
The system must be capable to read a HTML file stored on the SD card (including pictures) and create a web server accessible via WiFi (acting as an access point). When the user is connected to the Wifi device-must type any direction like "http://192.168.1.100" and be able to load the HTML files stored on the SD. Something similar to a home router.
The HTML files must be able to read/write to the IO, analog and UART pins of the same microcontroller....
What we need from you are suggestions of the right hardware, software contributions and connections to anybody capable to help us.
Anyone? ;-)
@darren so the brite-view unit is good for 65 feet LoS, the Zinwell unit makes it 70 feet. As a rule of thumb doubling the range out of an omnidirectional antenna squares the amount of power required (sphere radius/surface area ratio); you are looking at doubling at least five times to reach slightly less than 1km, or (if my dodgy math can be trusted) increasing the energy those units use to about the 46th power.
Again, there is a correlation between modulation technique, information rate and input power required. The units you linked above are probably not doing anything particularly interesting; with halfway decent antenna design you can move HD video over wifi at those distances without breaking a sweat.
But this has no applicability to moving it over the sort of distances that we care about in this hobby, and there aren't actually any signs that it's "coming" as a product anytime soon at all. We need new information encoding techniques that haven't been developed yet, and that's leaving out completely some of the assertions that can be made about the fundamental lower limit on the energy/information curve.
It's great to be optimistic, but informed optimism is key. 8)
Well I guess I have not completely understood the.
A modified version of the dd-wrt.com on a Asus WL500GU should do... but maybe the hardware is not opensource?
Michael,
You are right but by adding an expansion board you will be able to have a full hdmi, usb, serial, cam interface.
Maybe taking a look on this VERY small board. Many options available. I love mine!
http://www.gumstix.com
Finally found what I was searching for yesterday... here are several examples of wireless HD. The only limitation I can see is LOS distance. Which by all means should be quite capable of being extended further given the frequency.
BriteView Air HD
Zinwell Wireless HD
@Michael, not sure you got what I was saying... all I was trying to get at was, hd video is coming; just not fast enough for us. for example look up Freefall video compression. they are claiming theyve got hd down to <1mpbs. which should ride 802.11a just fine... so dont take my previous posts too literaly. I too want more than 500 tv lines coming accross the airwaves :)
@Richard Read the spec again.
The W5100 is not a wifi device. The W610 module firmware doesn't provide the necessaries required to run HTTP out of the box (read the documentation, not just the webpage).
1
2
3
4
5
of 17 Next
