- Design a "thermopile replacement" version of ArduIMU: this is a version of the current ArduIMU board with a two-channel DAC and a FMA connector, so it can output voltage to emulate the FMA thermopiles.
- Design the turn-rate limiter shield hardware and software modification to the ArduPilot code: this is shield that has a one-axis gyro, a differential pressure sensor and a connector for the uBlox GPS. It will duplicate the functions of the UNAV PicoPilot but be better and a lot cheaper.
- Create and maintain a library of airframe.h configuration files
- Design the hardware for the ArduPilot Mega ground station (with dynamic PID adjustments). Similar to this.
- ArduIMU documentation
- Create an autopilot PID tuning guide
- Create a Lego Mindstorms compatible version of our MUX/Failsafe. This is just our current board with the addition of a Mindstorms connector and any necessary components for an I2C link. .
- Create a "Using ArduPilot with the Remzibi OSD" guide
- Create a ArduStation assembly and usage manual
- Create a system that can inject telemetry data on the invisible closed caption lines of a video stream and be able to decode it in the other side for the OSD system.
Interface inputs : SDO,SDI,CLK,CLEAR,LOAD
output : Analog out
#4 Any consideration for embedding PID into FPGA device(Coldrunner or IGLOO)?
(reference http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?tp=&arnumber=427...)
Would also give the capability of TDM communications which could include video streaming?
If I am off base in my assumptions. I would be willing to help in any area.
Rgrds
Sarel
have at it.
1
2
of 2 Next
