How I Integrated a Laser Rangefinder Sensor Into My Drone for Better Obstacle Avoidance and Altitude Control
Over the past few months, I’ve been working on a new drone build for surveying and mapping in mixed environments — from open fields to tree-dense areas. One of the biggest challenges I’ve faced is maintaining accurate altitude over uneven terrain and avoiding obstacles without relying entirely on GPS or visual navigation.
That’s when I decided to try integrating a laser rangefinder sensor into my UAV setup. I’ve used ultrasonic sensors before, but their range and accuracy were always limited, especially in windy conditions or when flying over irregular surfaces.
I ended up testing a TS1224 long-range laser rangefinder module from Meskernel Integrated Technology, and the difference was huge. This little module can measure distances up to 2000 meters with ±1 m accuracy, and it works great even when lighting changes — something that often confuses camera-based systems.
13676224892?profile=RESIZE_710x
Here’s what I’ve been using it for:
  • Obstacle Avoidance: Detecting trees, poles, and other UAVs before getting too close.
  • Precise Altitude Holding: Maintaining a stable height when flying over hilly or forested areas.
  • Survey Assistance: Getting instant, accurate distance readings to ground targets.
The module is surprisingly lightweight and supports multiple interfaces like UART, RS232, and RS485, so it’s been easy to integrate into my flight controller setup. For smaller builds, they also have compact millimeter-precision sensors in the LDL-T series, which are perfect for indoor inspection drones.
For anyone here who’s into DIY drone builds and wants to push their navigation accuracy further, I highly recommend giving laser rangefinder sensors a look. They’ve definitely changed the way I fly.
You can check out the specs and integration options here: https://www.lasersensor.net
