Posted by Jordi Muñoz on December 2, 2009 at 2:00pm
I love my Spektrum Dx7 and my 2.4Ghz JR XPS9303 and i refused to trade its solid rock performance by a 72mhz radio just to increase range of my FPV/UAV. So in collaboration with my friend JB we find out the cheapest and secure way to amplify the signal, it even works in some Futabas and virtually with any 2.4Ghz radio, but some modifications are required. Lets see some options:-Spektrum Dx7 this is the cheapest solution for a very reliable 2.4Ghz radio, i used it for about a year and i never had any signal glitch (unless i fly beyond 2000 feet). The problem with this one is that you have to modify it, you need a SMD to U.FL adapter, drill a hole in the side of your radio and just connect and screw the adapter, no soldering required. If you have more than 5 hours of experience with Legos your qualified to do this job. Then you just need to connect the booster. The one in the picture (middle) is already modified.-If you have the awesome JR radio but is 72Mhz you can buy the Spektrum 2.4Ghz module and just insert it in the back of your TX, personally this is my favorite setup. It's a good deal because includes a $99 dlls receiver for free! Note that JR TX alone cost around $600 dlls, but you can get it for less, i got mine for 300 bucks with Spektrum Module included on R/C Groups =P. Remember you are looking for the JR XPS9303.If you have one of the fallowing Futaba radios:7U Series Radios8U Series Radios8J Series Radios9C Series Radios9Z Series RadiosFN Series RadiosYou can just go and buy the Spektrum 2.4Ghz module, easy and with no hassles. It's also a good deal because includes a $99 dlls receiver for free!
One of the advantages of the Spektrum receivers is the build in diversity system, you can even buy one with 4 satellites like this one, or buy a super tiny, tiny setup like this one, or the traditional one.The diversity is crucial to have a reliable link when you are flying far away, also Spektrum has a receiver for Carbon Fiber airplanes (Carbon Fiber blocks RF signals).The idea is to have the best reliable hardware with an SMA connector and the SMA extension cable, after that you are ready for the final step: Get an amplifier. But we are talking about a few hundred dollars here, if you get the weakest one of 100mW it will cost you around $150 dlls. This is not pocket friendly in my point of view. So again our Asians friends come to the rescue, after making some research around the net I've found on eBay and a home Wireless Amplifier, so i decided to give it a chance and i bought it for 60 bucks including shipping! Wow that's a good deal! The one i got is this one.Note that the amplifier needs 6Volts to work, you can get a cheap 6V power regulator from here and just make the adapter. A 3 Cell LIPO is enough to supply it for a long time.
After receiving the AMP i did some tests, here are my results:Before using the amplifier, i was able to fly around 3000 feet away (~1 km) using a 900Mhz@500mW Video transmitter. I never lost the video signal, only the radio link...Using a 1.3Ghz@1Watt Video transmitter i was unable to fly more than 2000 feet away (~600meters). So the 1.3Ghz Video transmitter reduces my 2.4Ghz Spektrum range...Then i got my cheap Asian amplifier and using a 2.4Ghz Patch Antenna i was able to fly around 2.6 miles (4.18Km) away without a single glitch, but i was unable to continue because now my video was causing me problems, hehe!Not bad at all! Honestly i don't need more than 2 miles of coverage, is really a long way for an EasyStar. In conclusion the maximum range for my setup still unknown, but the range achieved is more that 2.6 miles and the +2 extra miles of coverage gained for less than $100 dlls is really a good deal for me!
Now just remember this:-The range will be different in other setups.-Never turn on your radio without antenna.-Never turn on the Amplifier without antenna.-Note that in some country's this amplifier may be illegal.Thanks for watching!
before you try this system , the 1.3ghz reduce your range with your 2.4ghz spektrum radio , and after the AMP hack with the same video link you was able to fly 2.6 miles ?
OK i have a long explanation for this... I complained with the Taiwan people because the box says 20 dBm, and 20dBm is about 100mW of input power support and the label on the unit do not correspond to the box specifications, so they are freaking out my costumers. They answered me that the label is a mistake (so sorry) and the unit is capable to support 20dBm.
Also he mention the life span of the unit, because this units are intenteded to be in a nasty invorement running 24 hours, 7 days a week, the 365 days of the year they recommend to use lower power to increase the life span (i guess to save money in the warranty or something). We only use it a few time a week, during 15 to 45 minute periods. Also if the unit is burned or switched off the RF signal just bypass thought the units as simple cable, so theres no risk to completely lost signal.
Now doing this calculation:
If Spektrum outputs 125mW, well to convert it to dBm you should:
-10xLog10(125mW)=20.96dBm (in ideal conditions).
But opps the recommended input power is 20dBm (we don't know the absolute input power might be more). So lets calculate the cable loss. If you use the recommended 5 feet cable located here:
Using this link we can calculate it. The RG174/u has a loss of 34 db/feet @ 1000mhz we are at 2400mhz so should be a lot more than that so i calculate that the lost for 2.4ghz would be around 65 db/feet, but less use 50 db/feet just in case, the result using 3 connectors (one internally of the RC, other external of the RC and another on the Amplifier), the loss is about: 3.1 dB (on ideal conditions).. You can also get 10 feet cable and that would a loss of 5.6dB.
So i guess we are fine, i been flying with this setup a lot of hours and i have not problems all. If you don't trust you can test it on ground first for several hours... ;-) Let me know if you have any problems.
Best Regards.
Max, also if you use a long cable like 10 feet's, will give you the liberty to move around and you will decrease the power a lot! But never mind if wrong i will change it.
The cables and connectors are attenuators =).. He recommends something?
Regards.
Best Regards.
Don't use it!! I just sent an email to the factory to ask whats going on, i guess they sent me the wrong units because mine doesn't have that label..
Open it, take a picture and post it here, look for the antenna connector...
Regards
15
16
17
18
19
of 19 Next
