I love my Spektrum Dx7 and my 2.4Ghz JR XPS9303 and i refused to trade its solid rock performance by a 72mhz radio just to increase range of my FPV/UAV. So in collaboration with my friend JB we find out the cheapest and secure way to amplify the signal, it even works in some Futabas and virtually with any 2.4Ghz radio, but some modifications are required. Lets see some options:-Spektrum Dx7 this is the cheapest solution for a very reliable 2.4Ghz radio, i used it for about a year and i never had any signal glitch (unless i fly beyond 2000 feet). The problem with this one is that you have to modify it, you need a SMD to U.FL adapter, drill a hole in the side of your radio and just connect and screw the adapter, no soldering required. If you have more than 5 hours of experience with Legos your qualified to do this job. Then you just need to connect the booster. The one in the picture (middle) is already modified.-If you have the awesome JR radio but is 72Mhz you can buy the Spektrum 2.4Ghz module and just insert it in the back of your TX, personally this is my favorite setup. It's a good deal because includes a $99 dlls receiver for free! Note that JR TX alone cost around $600 dlls, but you can get it for less, i got mine for 300 bucks with Spektrum Module included on R/C Groups =P. Remember you are looking for the JR XPS9303.If you have one of the fallowing Futaba radios:7U Series Radios8U Series Radios8J Series Radios9C Series Radios9Z Series RadiosFN Series RadiosYou can just go and buy the Spektrum 2.4Ghz module, easy and with no hassles. It's also a good deal because includes a $99 dlls receiver for free!
One of the advantages of the Spektrum receivers is the build in diversity system, you can even buy one with 4 satellites like this one, or buy a super tiny, tiny setup like this one, or the traditional one.The diversity is crucial to have a reliable link when you are flying far away, also Spektrum has a receiver for Carbon Fiber airplanes (Carbon Fiber blocks RF signals).The idea is to have the best reliable hardware with an SMA connector and the SMA extension cable, after that you are ready for the final step: Get an amplifier. But we are talking about a few hundred dollars here, if you get the weakest one of 100mW it will cost you around $150 dlls. This is not pocket friendly in my point of view. So again our Asians friends come to the rescue, after making some research around the net I've found on eBay and a home Wireless Amplifier, so i decided to give it a chance and i bought it for 60 bucks including shipping! Wow that's a good deal! The one i got is this one.Note that the amplifier needs 6Volts to work, you can get a cheap 6V power regulator from here and just make the adapter. A 3 Cell LIPO is enough to supply it for a long time.
After receiving the AMP i did some tests, here are my results:Before using the amplifier, i was able to fly around 3000 feet away (~1 km) using a 900Mhz@500mW Video transmitter. I never lost the video signal, only the radio link...Using a 1.3Ghz@1Watt Video transmitter i was unable to fly more than 2000 feet away (~600meters). So the 1.3Ghz Video transmitter reduces my 2.4Ghz Spektrum range...Then i got my cheap Asian amplifier and using a 2.4Ghz Patch Antenna i was able to fly around 2.6 miles (4.18Km) away without a single glitch, but i was unable to continue because now my video was causing me problems, hehe!Not bad at all! Honestly i don't need more than 2 miles of coverage, is really a long way for an EasyStar. In conclusion the maximum range for my setup still unknown, but the range achieved is more that 2.6 miles and the +2 extra miles of coverage gained for less than $100 dlls is really a good deal for me!
Now just remember this:-The range will be different in other setups.-Never turn on your radio without antenna.-Never turn on the Amplifier without antenna.-Note that in some country's this amplifier may be illegal.Thanks for watching!
  • I have an AXN floater Jet and a RDS8000 tx. I want to fly it FPV. I installed a 900mHz 500mW video transmitter. I wated to make a range test and realize the video transmitter was interfering with my airtronics reciever. It was not going to fail safe but the servo were not moving smoothly. Anybody had a similar problem and fixed it by using a signal booster? Would it work with the RDS8000 tx? Thanks
  • Admin
    Skyler,
    This booster is actually a transreceiver. I believe that the green led only lights up if it is transmitting otherwise it is in the receive mode. Since your picture does not show it connected to your RC transmitter of choice, this might be the problem.
    Just a thought.
    TCIII
  • Hi Jordi,I tried the booster today but the green led light only flickers on for a second then turns off, should I send it back? I posted a picture of the booster plugged in but led light off.
    Thanks Skyler
    DX-7 power amp kit...
    Low power DX-7 setup with RSMA adaptor...
    DX-7 rear velcro...
    DX-7 high power...
    DX-7 bind button access...
  • Tad,
    Do you have any idea of the loss (db/ft) of the Antenna RP-SMA Extension Cable 6M for WiFi Wi-Fi Router?
    Your amp appears to be a safe choice as it accepts 100mw input!
    I have completed my 500mw power amp setup for a DX-7. When not going for long range control, I use RSMA adaptor to connect higher gain antenna that came with power amp to DX-7. I use a 12" cable with 90° connectors between DX-7 and power amp. I have tested it for 10 hrs continuously with no problems. Mounted amp with velcro, powered with 1000 mAh 7.4 lipo. Balances well now!. Be sure to tighten the pass through SMA connector in TX case well, as it will loosen up when you remove antenna in future. I should be able to keep UAV in line of sight from Pikes Peak to Kansas border....but will RF links work?? It may only get to Falcon though, 10 miles out. I may need a parabolic dish for longer range testing... I only wish...
  • Regarding 1.2ghz.. its all about harmonics (2.4/2=1.2) thus occasional interference but there are video tx capable of 1080-1360mhz so playing with the channels it may be possible to get ride of the most of interference.. just a thought..
    Tad, can you post the links of the components you bought from ebay?
    Did you get significative improvement in terms of range?
  • Using the website provided I found that, according to the FCC ID of my dx5e, output power is 47mw (16,7dbm). With the U.FL RP-SMA cable and using the amplifier to get 500mw, is there still the risk of damage it?
    1- Nop, you may damagade the AMP but you can still fly (with less range)
    2- Yes you can bypass, the patch antenna will increase your range, but the cable will reduce it.
    3- Is all about the price $$$...
  • Three questions..
    1- Is there a risk to saturate rx using the amp and so not able to fly?
    2- It bypass the signal with no power loss when the amp is turned off?
    3- Why not using a amp with 200mw input (max), 2w output? I've seen a model that fulfil these features in the web.
