MR60
How-to guide: Pixhawk with 6S batteries (> 4S)
3689574013?profile=originalHi,
1. Introduction:
Pixhawk 3DR kit is delivered by default with a 4S maximum power module. For those wanting to use 5S or 6S or higher voltage batteries there is currently, to my best knowledge, no “how-to” guide for the Pixhawk board. I therefore decided to document it for others who might need it too.
For those who would like the same “how-to guide” for APM 2.x , here is a link I wrote a while ago:
http://www.diydrones.com/profiles/blogs/powering-your-apm-drone-or-how-not-to-shutdown-apm-like-the-us
Pixhawk comes standard with three (redundant) ways to powered it up:
1-USB : not used to fly obviously; just useful on the ground for connection on a ground station software.
2-The power module port accepting a maximum input voltage of 5.7volts (and will not get destroyed up to 20 Volts input)
3-The RC input pins. Will accept a maximum voltage of 5.7volts also (and is also protected up to 20 Volts)
This guide assumes a use of Pixhawk’s power module port which provides not only a way to power the board but also the pins to measure current and voltage values of the main battery.
This guide assumes a use of a 6S battery in combination with a Attopilot current & Voltage sensor board. This Attopilot “power module” replaces the 3DR 4S limited power module. The Attopilot board comes in three flavors: 45 amps, 90 amps or 180 amps.
3689573992?profile=originalThe choice of the right Attopilot board (45A, 90A or 180 A) will depend on your motor/props combination: take the Attopilot version that has the smallest amps capacity above your max multicopter current consumption. However we will introduce in this guide a way to use the 90 amps Attopilot board to measure up to 150 amps, still using Pixhawk’s power module port.
2. Attopilot description:
An Attopilot board provides three wire soldering pads to solder : a current measurement wire, a voltage measurement wire and a ground wire. See picture below:
3689574026?profile=original
Attopilot 90A support up to 50Volts for a maximum of 90A. However the resistor specifications exceed the 90A limitation which makes it possible to use it for measuring 150 amps (we will take this as a assumed max current as our example for the rest of the explanation).
The datasheet of Attopilot specifies that the Voltage measurement wire outputs an analog voltage of 63,69 milliVolt per Volt. Similarly the current measurement wire outputs an analog voltage of 36,60 milliVolt per Volt.
So for a 6S battery the maximum analog voltage values will be:
-For voltage measurement: [min 0V -  max 1.6V]
-For current measurement: [min 0V – max 3,3 V]
3. Pixhawk power port description (pinout):
3689574113?profile=original
Reusing the excellent pixhawk infographics published in the wiki, the image shows circled in yellow where the power port is on the pixhawk board.
The power port is a so-called DF13 connector with 6 pins.
The six pins of this connector are assigned in the following order, starting by the red wire on the leftmost pin:
Power Port Pinout Description:
  • 1- Vcc (5V input)
  • 2- Vcc (5V input)
  • 3- I (Battery current measurement analog voltage input)
  • 4- V (Battery voltage measurement analog voltage input)
  • 5- Ground
  • 6- Ground
4. Wiring Case 1 : to measure up to a maximum of 90 amps
The connections between Attopilot and Pixhawk are shown in the illustration below:
3689574082?profile=original
We have added an optional BEC in the illustration that would be connected to the Vcc and Ground wires of the power module. It is optional as Pixhawk could alternatively be powered via the RC inputs.
4. Wiring Case 2 : to measure up to a maximum of 150 amps
The connections between Attopilot and Pixhawk will integrate resistors to be able to measure up to 150 amps.
Indeed the ADC of this power port on Pixhawk has a range of 0-3.3V. This means that for the maximum true current of 150 amps, we want the current analog wire of Attopilot to output maximum 3.3Volts (as it is the case in case1 for 90 amps max without additional resistors).
Note : this part has been updated with a resistor scheme simplification (only one resistor to add in parallel rather than the originally classical R1, R2 resistors divider) thanks to a contribution of Bo, a diydrones member who analyzed in depth the Attopilot circuitry.
So we will build a small resistors divider on wire 3 (current measurement) & wire 5 or 6 (Ground) as follows:
3689574212?profile=original
The Attopilot current measurement output masks a circuit that contains an existing output resistor called Rl. According to the Attopilot datasheet, the following equation links to measured current I (called MeasuredCurrent in the equation), the output analog voltage for current measurement Vout, and an existing Rs resistor in Attopilot:
3689574168?profile=original
 What we want is to get Vout = 3,3 when Current =150 amps. To do this we will add a new external resisto (Rx) in parallel with the existing Attopilot Rl resistor, so that the new resulting Rl resistor (called Rl’) must be (knowing that Rs = 0.5Mohm as per Attopilot specs):
3689574150?profile=original
Therefore we can calculate the Rx resistor value we need to add in parallel as follows:
 3689574221?profile=original3689574230?profile=original
So, Rx must be ~ 110kohm to have a Vout at 3.3V when the measured current is 150 amps.
You can choose another max amp output (but I would not advise higher than 150 amps with the 90 amps Attopilot, otherwise use the 180 amps version instead) and calculate the resulting Rx resistor
As a result, when the current is 150amps, Vout will have value of 3.3Volts.
5. Mission planner / parameters configuration in battery monitor screen:
In the battery monitor parameters screen, you can manually select which current and voltage sensor you are using. In the present case, you will select the power module and modify the following parameters to make the mission planner voltage and current display match the real values (measured using a wattmeter for example). The explanation below is an extract from the Arducopter parameters list.
Battery monitoring (BATT_MONITOR)
Controls enabling monitoring of the battery’s voltage and current
Value
Meaning
0
Disabled
3
Voltage Only
4
Voltage and Current
Battery Voltage sensing pin (BATT_VOLT_PIN)
Setting this to 0 ~ 13 will enable battery current sensing on pins A0 ~ A13. For the 3DR power brick on APM2.5 it should be set to 13. On the PX4 it should be set to 100. On the Pixhawk powered from the PM connector it should be set to 2.
Value
Meaning
-1
Disabled
0
A0
1
A1
2
Pixhawk
13
A13
100
PX4
Battery Current sensing pin (BATT_CURR_PIN)
Setting this to 0 ~ 13 will enable battery current sensing on pins A0 ~ A13. For the 3DR power brick on APM2.5 it should be set to 12. On the PX4 it should be set to 101. On the Pixhawk powered from the PM connector it should be set to 3.
Value
Meaning
-1
Disabled
1
A1
2
A2
3
Pixhawk
12
A12
101
PX4
Voltage Multiplier (BATT_VOLT_MULT)
Used to convert the voltage of the voltage sensing pin (BATT_VOLT_PIN) to the actual battery’s voltage (pin_voltage * VOLT_MULT). For the 3DR Power brick on APM2 or Pixhawk, this should be set to 10.1. For the Pixhawk with the 3DR 4in1 ESC this should be 12.02. For the PX4 using the PX4IO power supply this should be set to 1.
This is a parameter to adjust to match the real Voltage value with the displayed mission planner value.
Amps per volt (BATT_AMP_PERVOLT)
Number of amps that a 1V reading on the current sensor corresponds to. On the APM2 or Pixhawk using the 3DR Power brick this should be set to 17. For the Pixhawk with the 3DR 4in1 ESC this should be 17. Units: A/V.
There you go! I hope this will help you configure your pixhawk with higher than 4S batteries.
Cheers,
Hugues
  • Huges;
    #With the version with 4 mm or 5.5 mm and 6mm gold plated plug, and also the version with the silicon cable, only the positive terminal of battery and controller are connect directly to the UniSens-E. For the negative pole there is a short silicone cable. This separate negative pole only needs to be connected to the negative pole of the battery when the speed controller is equipped with an opto-coupler. Then the UniSens-E is missing the ground reference needed for measurement. With BEC regulators, the cable should be insulated with shrink tubing and just remain free.
    The UniSens-E with a 5.5 mm or 6mm gold plated plug, and also the version with the silicon cable, does not have a plug on the single negative cable. Here a small connector should be attached with which the connection is made to the negative terminals of the battery. Well proven here is a 2 mm gold plated plug.#
  • also,not long ago it was possible to use graupner telemetry with px4(not Pixhawk)
    http://diydrones.com/profiles/blogs/px4-autopilot-gets-graupner-hot...
    it was possible on APM2.X as well
    http://diydrones.ning.com/profiles/blog/show?id=705844%3ABlogPost%3...
    and also there is interesting conversation or maybe problem solved on Github
    https://github.com/diydrones/ardupilot/issues/631
    all this is a bit beyond my knowledge or I am just lazy and would like step by step instructions
  • hey....it can use any of this RX/TX
    In accordance with our philosophy to support many systems, the UniSens-E also speaks the language of
    Jeti Duplex (EX),
    Multiplex M-Link
    Graupner/SJ HoTT
    Robbe/Futaba FASSTest S.BUS2
    JR DMSS
    FrSky
    measuring according to connectors
    3. Technical Data
    Current range: 140 A in both directions, ie – 140A to + 140 A
    Following durations are allowed:
    - 100 A unlimited
    - 120 A for 1 minute
    - 140 A for 20 seconds
    Depending on the plug-in system, but the limitations of the plug are much lower!
    Reasonable values are as follows:
    - MPX green (double contact) and XT60 Continuous: 50 A / 20 s: 70 A
    - 4 mm gold plated plug Continuous: 80 A / 20 s: 100 A
    - 5.5 mm gold plug Continuous: 120 A / 20 s: 150 A
    - 6.0 mm LMT gold plug Continuous: 120 A / 20 s: 150 A
    Voltage Range: 0 to 60 V
    Altitude range: 0 to 8000 m above sea level, automatically zeroed at switch on
    Receiver Voltage measurement: 3.8 V to 10 V
    Data Rate: 10 Hz
    Power supply: from receiver supply via the telemetry connection (from 3.8 V to maximum 10 V)
    Power consumption: 25 mA from the receiver supply
    External Connectors: 1 x connector for telemetry and power ("Link")
    1 x phase connection for the brushless rpm measurement
    1 x Servo signal input from the receiver
    COM port for UniDisplay, GPS logger or PC
    Dimensions: green MPX connector: 26 (38) x 29 x 9 mm Yellow XT60 connector: 26 (50) x 29 x 9 mm 4mm gold connectors: 26 (55) x 22 x 9 mm 5.5 mm gold connectors: 26 (44) x 22 x 11 mm
    6.0 mm LMT gold connectors: 26 (44) x 22 x 11 mm
    Weight: 10 g - 14 g without cable (depending on connection), cable 4g
    detail informations can be found in English translation of manual.
    ..hm yes,its similar to attopilot 180A
  • MR60
    @Emin, seems like an interesting sensor system. I however do not understand a few critical points I like to check on an amps/votlage measurement system:
    -their connection scheme when they say the sensor only needs to connect on the +line and not on the ground. At another place in the manual it says ground uses just a small silicon wire.
    -their connectors : the offered connectors (e.g. XT60 or bullet connectors) are not compatible with the amps they claim. Indeed XT60 is meant for maximum continuous 60 amps, certainly not 140 amps.
    -their wire sections  : do not match their claim to measure 140 amps neither.
    -the I, V measured analog outputs : not clear if this is provided. It seems the ouput is meant only for certain receiver brands : JETI, etc.
  • Emin
    You could use attopilot 180A and up to 14s then you will have over 9Kw of power...
    Enough for most of us...
  • ..it will be useful for testing motor prop esc combinations as well...it can measure 200A and (400A 1 min.bursts)it depends on plug(EC5 I use)..and since it measures height and speed also, why not use for control or helping baro on Pixhawk?
  • 3701683966?profile=originalI will go this way UniSens-E
    all the data you want
    • complete measurement of electric drives with current, voltage, power, capacity, speed and height measurement
    • integrated brushless speed sensor
    • full telemetry support for Jeti Duplex (EX), Multiplex M-Link, Graupner HoTT, Robbe / Futaba FASSTest S.BUS2, JR DMSS and FrSky
    • Height measurement with automatic zeroing after switching on
    • barometric Vario
    • Current measuring range up to 140 A in both directions, voltage up to 60 V
      (the maximum current carrying capacity of plug used but must not be exceeded!)
    • Connector for signal receiver for remote control of certain functions
    • direct connection to the GPS logger possible to record data in a file
    • Measurement of the receiver battery voltage
    • Powered by recipient
    • current status is indicated by LED
    • direct viewing of live or recorded readings with our UniDisplay
    • Parameter settings via PC, UniDisplay and telemetry possible
    • PC software for settings and updates ( SM UniSens E-Tool ) is here  available
    • free firmware updates via PC with our USB interface (Order No. 2550) or with existing USB connection cables as of Jeti, multiplex or Graupner possible (the firmware file, click here )
    • Due to its compact size and low weight can be used almost anywhere
    English manual:
    http://www.f5b.co.uk/uploads/2/5/8/0/25805878/unisens_e_v1.07.pdf
    hoping one day I will find a way to connect this to pixhawk
  • As I need 12v for video TX and gimbal controller card i have a 3s lipo onboard, the ESC/motors run on 6s.
    I want to power the pixhawk from the std. APM Power module from the 3s and monitor the U and I on the 6s Battery
    I also power Pixhawk from a 5V bec on output rails for redundancy.
    I wired it like this...And it works just fine
    3701683576?profile=original
  • hm,my problem is measuring 100-150-200 A, I decide to fly on 4S bcs its more efficient...
  • ok,,,,,, guess Chinese are moving ahead of 3dr in this sense: http://www.ebay.com/itm/Power-Module-V1-0-Pixhawk-APM2-5-APM2-6-Ard...
    90A up to 8s :))
