I Heart Robotics UAV Crosspost
While not all of the information on the I Heart Robotics blog is related to UAVs, there is a significant amount that should be of interest here. I would like to highlight a few specific posts.Autonomous Indoor HelicoptersHighlighting the development of an indoor helicopter navigation system.Crash TestThis is a series of posts that shows the process of developing an autonomous quadrotor helicopter based on the Dragan FlyerUAV Damage ControlSome information about adaptive control and morphing aircraft.Analog Devices IMU now available with integrated MagnometerInformation about an analog devices IMU, ideally this sensor could be supported by the next version of ArduPilot.If this kind of summary crosspost is considered helpful I can probably do it on a semi-monthly basis, otherwise this post can be deleted.
  • Fiducial matching is an interesting localization technique -
    http://www.roborealm.com/help/Fiducial.php
    Fiducial Marker
    RoboRealm is a powerful vision software application for use in machine vision, image analysis, and image processing systems. Using an easy to use poi…
  • On second thought, if you didn't have enough processor cycles on board that could be an advantage for unidirectional sonar.
  • While the 1-3cm accuracy is good, I don't see a huge advantage of sonar beacons over IR beacons and from what I understand computer vision results may be adequate for beacon identification. I saw a paper recently where they were able to track bar codes in realtime using computer vision.
    Actually I think this shows how well the realtime computer vision stuff has come along for stuff like beacons.
  • unidirectional sonar -
    http://cricket.csail.mit.edu/
    The Cricket Indoor Location System: An NMS Project @ MIT CSAIL
    Pervasive computing, sensor networks, tracking, location, space, coordinate, orientation, GPS, Cricket, indoor, mobile networks, wireless netwo…
  • The Timedomain stuff is interesting but at 0.3m accuracy you might as well buy a Hokuyo laser and do localization in software..
    The MSSI UWB Radar system looks pretty nice but I doubt that it is flyable yet on anything less then a 0.90 size nitro helicopter. They did manage to fit it on a Packbot though.
    Is there a DIY Drones wiki or something where all this sensor information compiled?
  • Just take out a home equity line of credit & go to
    http://www.timedomain.com/
    & the video yet again.
    Sonar position sensing is still the domain of hobbyists & isn't being sold yet.
  • The quadrotor with the sonar sensors was setup for outdoor use and more to avoid hitting anything then anything else. Also the idea was that mapping could be done by using the IMU and optical flow with the sonar sensors and it could scan the area as the vehicle maneuvers.
    Do you have a link/price for the UWB or unidirectional sonar sensors?
  • Reflected sonar navigation has been tried & abandonned before. Our notes go like this:
    You'd have to always fly 1 meter away from & orthogonal to 2 walls. It's a $75 tag just for 1 down & 2 sideways sonars. You'd single handedly bail out Minnesota's mortgages.
    If you covered the thing in sonar transducers, you might be able to map the surroundings, but for that money you could get a UWB system.
    The way people are doing it now is unidirectional sonar.
    Helicopter tails rotor he?
