Another of the same plane but in french.It is 4 channels with full throttle, aileron, rudder and elevator control. I am interested in using this platform for my photo/video but I have been reading terrible reviews on the plane. People say the dihedral on the arelons causes the ESC to get super hot. I haven't flown mine yet. It is all put together and hanging where I can look at it, but so far I haven't been able to arrange a good day off from work to go try it out.I am still looking for the perfect platform.Lately I have seen the HawkEye system to be FANTASTIC and have been saving money to get one.I wonder if it could be set up with all the fancy autopilot stuff?Also, Mike Powers from Whispershots.com has AMAZING platforms. He has been very kind to tell me where to get his plans in kit form and I am going to be ordering very very soon!The one I like the most is the Passive system.
For my FPV camera, I have this:
I have a 2.4 wireless Cam set up called the Draganfly Eyecam.
Specifications:
Camera and transmitter weight: only 9 grams
Camera and transmitter size: 15mm x 22mm x 32mm (5/8" x 7/8" x 1 1/4")
Camera Lux: <3 @ f1.2
Camera Auto Electronic Exposure of 1/60 to 1/15000 sec. w/ Auto Gain & White Balance
Camera Signal to Noise Ratio:48dB
365K (PAL) camera pixel resolution
Wireless Transmission Range: 300M (1000'), Line-Of-Sight
Transmitter RF Output Power: EC R&TTE Compliant
receiver Video Input/Output: 1Vp-p/75 ohm
See More Info Here.
I plan to use these as my first Goggles. They are cheap but should work fine for now.
Specifications:
Video input format: NTSC/PAL/SECAM automatic selection
Virtual Image Size: 50 Inches as seen from 6 ½ feet
Resolution: 230,000 pixels per LCD
Color Depth: 24-bit input
Viewing Angle: 26 degrees diagonal
Video Input: Composite AV
Audio: Dual-channel stereo
Power Supply: Built in 480mAH rechargeable battery
Power Consumption: <0.45W
Net Weight: 4.2 Oz (119g)
More info here
The Supercub has had a recuring electronics issue. I crashed it hard again (thank god I didnt put the cam on yet). The cub is back together but the electronics seem messed up (power goes in and out - servos move with no input from reciever). I ordered a new replacement plane and it should be here Monday. I cant wait. I will install the draganfly eyecam on the new plane.
The plans are fantastic. I am about to order several of them in the next few months.
1
2
of 2 Next
