We're delighted to announce the new APM 2.5+, which is the same APM 2.5 board you know and love but surrounded by lots of new goodness! Now, for a new lower price of $179, it comes with all this, right out of the box:
- The new APM 2.5 enclosure, available in both top pin (above) and side pin (right) styles. It's designed to keep your electronics safe while looking great at the same time! The enclosure is made of black translucent ABS plastic so you can see the board's LEDs. It protects your electronics while allowing access to all pins and connectors. The inside of the enclosure is lined with ESD safe open cell foam to ensure the barometric pressure sensor is surrounded by static air and prevent unwanted readings due to airflow over the sensor. And the screws that secure the enclosure have been moved to the top for ease of use. It's also available as a stand-alone product for $4.99. (customers who already have an APM 2.5 are eligible for a coupon code to get a free enclosure with their next order. Email sales@3drobotics.com if you don't already have one)
- The new APM Power Module, available with either XT60 (shown) or Deans connectors. It's a simple way of providing your APM 2.5 with clean power from a LiPo battery as well as monitoring current consumption and battery voltage measurements, all through a 6-pos cable that plugs in neatly. The board is also shrink-wrapped to protect it (the bare board is shown here so you can see the innards). Been wondering what that "mystery connector" was on APM 2.5? Now you know! This will ensure that you have no brown-outs due to insufficient BEC power from your ESCs, and makes current and voltage monitoring easy! It's also available as a stand-alone product for $24.99
- Our new Version 2 of the Mediatek GPS module. This takes all the learning we've had with the Mediatek over the past two years and wraps it up in one vastly improved product. New big ground plane antenna to improve reception! On-board battery for fast lock! New firmware for better performance and datalogging! Also available as a stand-alone product for $37.95.
Oh, and did I mention that we also lowered the price of APM 2.5 by $20 at the same time?? This is all thanks to our new production facilities in Tijuana, which allow us to make an increased volume of products at higher quality and lower prices. We're even adding a new Manncorp four-head pick-and-place machine there to handle even higher volume!
Our initial testing still shows the uBlox giving slightly better results. We'll try to do proper head-to-head comparisons with data over the next couple weeks, but at the moment we're comfortable recommending either.
I too would like to see a comparison of the new Mediatek vs the old and the uBlox
velcro?
For portability, couldn't you just buy a couple of extra cases and double tape the bottoms to various vehicles and then move the board and top around or is the board taped into the case? Just a thought for moving it around. The screws to hold it together are on top so it should be fairly easy to move around if you get a few cases.
Rubber damper washers? What are these? Same as I'm using?
The only thing I would have done better on the new case is a bit more height to allow the dampening rubber washers to be less compressed when you close the case. Not sure how much they still absorb at the moment as you really need to compress them all the way to make sure the case closed properly. Looks like the rubber washers are an after-taught... (or not if they work as supposed when super compressed)
2mm more height would have make me happier! :)
And maybe as Robert indicated, an option to have a bottom screw to the frame (but 90% of the people use double side tape so not a big deal) Again hard mounted induce more vibration, double layer or 3M thick double side tape is great (but a pain to remove when you want to take it to another frame) Still room for improvement on the mount. Maybe a super duper quick disconnect for next version (I call it first! hehe)
Dany
Canada Drones
Oh my order was placed yesterday. Don't know how I missed the new version.
Hi Chris, sorry if this is not the appropriate place to post this but I wanted to make sure it got seen in time. I emailed sales@3d… also.
I ordered APM2.5 unassembled with new power module and now just saw this post :-/ I also got it with uBlox
How can I change my order to the new lower priced one? I got basically the same thing but was $275.
I think this question was asked earlier but I couldn't find a response. Which GPS option is the best? Mediatek or Ublox?
Jerry, I have heard that Digikey is like that, but I haven't had the pleasure of ordering there yet. It sounds like they are like McMaster-Carr. I have ordered as late at 5:30PM, and had the product at my desk before noon the next day, and for an astoundingly low price. Typically on the order of $11 to ship a few pounds of stuff across the border overnight. I can't even overnight a letter across the city for that price. I really don't know how they do it.
