Quadcopter Drone Flying Characteristics
All in all the JJRC Quadcopter Drone is a very robust, stable flyer. Changing the direction the Quadcopter is pointing towards (the yaw rate) is not spectacular in low rates but is quite acceptable in the top 100% mode. However when flying in this mode be aware any sharp movement on the right stick (mode 2 flying left hand throttle stick) the RC Quadcopter Drone will enter into acrobatic auto-flip mode and perform tight flips.
The LED lights will start a flashing sequence when the battery life is running low. Be warned you don’t get much time left to land the Quadcopter Drone so it is better to fly this model using a timer. Lipo batteries last longer if you don’t run them right down so using a timer has double benefits. Remember to let the motors cool down if you have spare batteries ready to go.
Quadcopter Drone Body Styling
The body shell of the JJRC 1000A resembles that of the much larger DJI Phantom and is a welcome change from all the Hubsan X4 look-a-likes. The propeller blade shapes are of a very similar shape to those used on the Walkera QR Ladybirds albeit slightly larger.
Quadcopter Drone Transmitter
A real plus with this model is you get a ‘Proper’ sized Remote Control RC Quadcopter Drone Transmitter. Nearly all under $30 Micro and Mini Quadcopter Drones have tiny transmitters that are OK for smaller hands but can cause stress for those with larger hands. It is therefore plain to see that this under $30 Drone is a great learning tool and will teach any beginner the basic Quadcopter flying skills. It will also prepare YOU well if and when YOU want to move up to bigger Quadcopter Drones.
JJRC Quadcopter Drone Review from Drone Flyers
We took the JJRC 1000A outside today and had a blast with it. We can’t get over how quiet it is unlike some of the other Quadcopter Drones in this class. The lightweight body shell and larger size propellers don’t seem to strain the motors and in 100% mode the flips are awesome. It was a pleasure to fly, fast and easy to control.
Over the next few weeks the Drone Flyers Team are going to put this RC Quadcopter Drone through some rigorous testing. Having flown the JJRC 1000A indoors over Christmas and studied all the Best Drone Reviews of this model we are certain that this is one of the finest under $30 Quadcopter Drones you can buy.
Quadcopter Drone Description
Item Name: JJRC 1000A Quadcopter Drone
Frequency: 2.4G
Channel: 4
Gyro: 6 axis
Battery: 3.7V 250mAh lipo
Flight time: 5-8 minutes
Quadcopter Drone Battery charging time: about 40 minutes
Control distance: about 80-100 meters
Size: 12 x 12 x 2.5cm
Color: White
Quadcopter Drone Features
Latest 6 axis gyro system
Mini size, super light weight
With LED light function
Compatible with transmitter of V202 V222 V262 V272 JXD 385 388 X30 X30V F180 L6036 L6038
Quadcopter Drone Package includes
1 x JJRC 1000A Quadcopter Drone
1 x LCD Quadcopter Drone transmitter
1 x 3.7V 250mah battery
1 x USB charging cable
4 x spare blades
1 x Quadcopter Drone manual
More quadcopter DIY article here :http://www.rcdronegood.com/
