Laser Distance Sensors for UAV & Gimbal Integration – Lessons Learned the Hard Way
Hey everyone,
I’ve been working on a few UAV payload / gimbal integration projects recently, and one topic keeps coming up during design reviews:
“Which laser distance sensor should we actually use on a drone?”
On paper, lots of sensors look great. In the air… not always. I wanted to share a few practical lessons we’ve learned when selecting and integrating laser distance sensors for UAVs, and I’m curious how others here handle similar trade-offs.
1. Range is overrated, weight isn’t
Early on, we kept chasing longer range specs. In reality, most UAV applications don’t need kilometers of range — but they do care about:
  • Payload weight
  • Mechanical integration
  • Power draw
We’ve had much better results with sub-10g or ~15g modules that fit cleanly into a gimbal or pod, even if the max range is “only” 60–150m.
Once you factor in vibration isolation, connectors, and airflow, smaller flat modules are way easier to work with than long cylindrical housings.
Curious: how much payload margin do you usually reserve just for sensors?
2. Phase vs pulse – depends on what your control loop needs
A mistake we made early was picking sensors based purely on max distance.
Phase-based (iToF) sensors
  • Higher update rates
  • Better repeatability
  • Lower latency
These work really well for:
  • Terrain following
  • Relative altitude
  • Gimbal stabilization feedback
Pulse-based (dToF) sensors
  • Much longer range
  • Solid outdoor performance
  • Lower update frequency (often 1–5Hz)
Great for surveying or long-range spotting, but not ideal if your flight controller expects fast feedback.
In our experience, latency hurts flight behavior more than raw accuracy.
3. Sunlight and surface type matter more than expected
Another thing that surprised us: laser wavelength actually matters outdoors.
  • Red lasers are efficient and low power
  • Green lasers tend to behave better on:
    • Reflective terrain
    • Water or liquid surfaces
    • Bright sunlight conditions
For low-altitude outdoor missions, green laser modules sometimes gave more stable readings than we expected, especially when the surface wasn’t “ideal.”
Has anyone else seen big differences just from wavelength choice?
4. Update rate > accuracy (most of the time)
We tested a few sensors that were very accurate… but only updated at ~10Hz.
Once airborne, that caused:
  • Laggy altitude response
  • Oscillation during hover
  • Poor terrain tracking at speed
High-frequency sensors (hundreds of Hz or even kHz-level internally) made a huge difference in closed-loop behavior, even if the absolute accuracy wasn’t perfect.
If your controller runs fast, your sensor probably should too.
5. Integration pain usually comes from interfaces, not optics
Distance data is useless if it’s hard to integrate.
Things that saved us time:
  • TTL / UART at 3.3V
  • RS485 for noisy payloads
  • Simple ASCII or Modbus protocols
  • Multi-sensor bus support
The more “embedded-friendly” the sensor is, the faster you get from bench test to flight test.
6. Customization is basically unavoidable
In almost every UAV project we’ve touched, something needed to be customized:
  • Connector type
  • Cable length
  • Mounting structure
  • Housing for dust / humidity
  • Protocol tweaks
Off-the-shelf sensors are great for prototyping, but OEM flexibility becomes critical once you move beyond a single prototype.
Final thought
For drones, the best laser distance sensor is rarely the one with the longest range or the prettiest datasheet.
It’s the one that:
  • Fits your payload
  • Matches your control loop
  • Survives sunlight and vibration
  • Plays nicely with your electronics stack
I’d love to hear:
  • What sensors are you using on your UAVs?
  • Phase or pulse?
  • What integration issue surprised you the most?
Looking forward to the discussion
