Laser Rangefinder LD30-S1R(LDL-T) → Companion Computer → Pixhawk Flight Controller
This guide provides a fully working, no-extra-documentation-needed solution to integrate:
LD30-S1R → Companion Computer (Raspberry Pi / Jetson / Android) → MAVLink → Pixhawk
It includes wiring diagrams, data parsing flow, ready-to-run Python code, Pixhawk parameter setup, and ground control station verification.
Follow this guide step-by-step and the system will work immediately.
1. Wiring Connections (LD30 ↔ Companion Computer ↔ Flight Controller)
1.1 LD30-S1R ↔ Companion Computer (UART)
Companion computers can be:
Raspberry Pi / Jetson Nano / Industrial PC / Android device with USB–UART
LD30-S1RCompanion Computer (UART)
VCC (3.3–4.0V)3.3V or external regulator
GNDGND
TXD (open-drain)RX
RXDTX
PWRENPull HIGH (3.3V) or GPIO
nRSTNot connected
Note: LD30 uses 3.3V TTL UART. Do not connect to 5V TTL UART.
TX is open-drain; internal pull-ups on Raspberry Pi and Jetson work fine.
1.2 Companion Computer ↔ Pixhawk (MAVLink UART)
Use TELEM1 / TELEM2 port.
Companion ComputerPixhawk (TELEM Port)
TXRX
RXTX
GNDGND
  • Baud rate: 115200
  • Protocol: MAVLink2
2. Reading LD30-S1R Data on the Companion Computer
LD30 communicates using a binary command protocol.
The companion computer handles:
  1. Open UART port
  2. Send “continuous measurement” command
  3. Parse frames beginning with 0xAA
  4. Extract distance (mm)
  5. Convert to meters
  6. Pack into MAVLink DISTANCE_SENSOR
  7. Send to Pixhawk
2.1 Continuous Measurement Command
From LD30 User Manual (section 14.12):
AA 00 00 20 00 01 00 04 25
2.2 Data Frame Format
Returned data includes:
  • Distance: 4 bytes (mm)
  • Signal quality: 2 bytes
  • Frame header: 0xAA
3. Complete Python Script (Ready to Run)
visit:  this guide
✔ Reads LD30
✔ Parses distance
✔ Converts mm → m
✔ Sends MAVLink DISTANCE_SENSOR
✔ Streams data to Pixhawk in real time
4. Pixhawk Parameter Configuration (Mission Planner)
Go to:
Config → Full Parameter List
Set the following:
ParameterValue
RNGFND1_TYPE10 (MAVLink)
RNGFND1_MIN_CM3
RNGFND1_MAX_CM3000
RNGFND1_ORIENT0 (Forward) or 25 (Downward)
RNGFND1_RMETRIC1
SERIAL1_PROTOCOL2 (MAVLink2)
SERIAL1_BAUD115
If using TELEM2, use SERIAL2_*
If using TELEM3, use SERIAL3_*
5. Monitoring LD30 Data in Mission Planner / QGroundControl
5.1 Mission Planner
Navigate to:
Flight Data → Status → sonar_range / rngfnd1_dist
or:
Ctrl + F → MAVLink Inspector → DISTANCE_SENSOR
You will see:
  • Real-time distance
  • Update frequency
  • MAVLink stream ID
5.2 QGroundControl
Navigate:
Widgets → Analyze Tools → MAVLink Inspector → DISTANCE_SENSOR
