Dear friends, I would like to introduce you the RTKite GNSS RTK L1+L2 module receiver.
http://northsurveying.com/index.php/instruments/gnss-rtk-receiver
Designed specifically for Pro and Semi-pro UAV, Robotics and Industrial applications, it connects directly to the Pixhawk and other autopilots and is specific for millimetric Photogrammetry, LIDAR Scans, Themography, etc.
The RTKite is a full Receiver (not a basic GNSS board) with an internal OS that can connect directly to standard CORS stations with its embedded GSM/GPRS cellular modem, can be configured and operated by Bluetooth, COM or TTL communications and can be set with our freeware for Android, Windows PC or WindCE or Linux, or even with text string commands.
It also can receive and transmit RTCM or CRM correction signals by UHF radio or our unique AutoCaster system that allows direct link connection by the integrated mobile modem with an stable transmission range of 75Km on Fixed position.
In is in fact a miniaturization of our professional surveying RTK receiver SmaRTK, (first generation released on 2012), and is compatible with our unique AutoCaster system for direct Base to Rover cellular data link.
Below, an Autocaster test on a modified DJI drone with Pixhawk and the RTKite GNSS with the lightweight helical antenna.
@Emin Bu.
Just want to bring to your attention that the RTKite is a professional Double Frequency (L1+L2) military-grade GNSS RTK receiver, and we offer lifetime service and free customization and personal integration support.
"Low cost" doesn't mean "cheap", it means that, compared to simmilar specifications it is below its target price. For perspective, since the model introduction 6 months ago, the receiver is already in its 3rd hardware generation and 15th software generation, and integrated in more than 10 different types of industries, no just UAVs.
If you are looking for "cheap" RTK solutions, I recommend you to look for Single Frequency (L1) systems, that can fit the purpose of testing but cannot perform on the conditions that our aerospace customers need, that is real time, within seconds, all the time, in non-optimal environments.
Low cost???
" The Receiver with antenna has a price of $ 2,300.00 a pack of battery charger, charger and USB Cable Usd$ 300.00, and the UHF Radio Modem Module Usd$ 400.00, plus the dispatch from Barcelona. If you like more details please write to: Emea@Northgps.Com"
https://www.facebook.com/north.surveying/posts/992972254082374
@andru88 Very good!
It would be interesting if you make post of integrations for the community to understand better how RTK systems work, it would help everyone.
Bernardo Espinosa
Thanks, but I'm not interested because of the high valuable. I myself can integrate GNSS board , where I need to . ))
@andru88, indeed we don't use Novatel. We are professional GNSS RTK producers with 10 years on the RTK market.
We supply directly to integrators and representatives, and yes, it is low cost compared with the main players of the GNSS market.
The RTKite receiver is integrated now not only in UAVs but in robotics, precision agriculture, machine control and other industries, however we are making it available to the Semi-Pro integrators as well.
If you need any datasheet we have everything publicly available: www.northsurveying.com
But now it is clear that this can not be a low cost .
Novatel is not a competitor for a low price ) )
It is called OEM-V Form factor, and defines the location of drill holes:
20 pin is a format set by Novatel and used by many brands for compatibility, including North:
North RTKite GNSS Receiver http://northsurveying.com/index.php/instruments/gnss-rtk-receiver
@andru88,
thank you.
It looks like market is full of L1 + L2 GNSS RTK receivers.
What is a price ?
the side
