Mapping with Ardupilot
I've been playing with ArduPlane for quite a while and have finally got to the point where I can make it do something useful. I've been inspired by others on this site to use it for aerial photography to make 3D maps and the like.
I have an ST Models Discovery as the airframe (awesome platform for Arduplane by the way) and have made my own camera mount out of plywood for the bottom. It has one servo for roll stabilisation using CHAN 8 on the autopilot to keep the camera pointing down. It's basic but works pretty well (see pics)
3689430890?profile=original
3689430908?profile=original
Last weekend I flew over a small island on the river near my house. I managed to get 155 photos in around 10 mins and produce quite a reasonable 3d surface using hypr3d. I gotta say that these guys rock with great personal service and it's all free! They did struggle a bit with that many photos, but you can see the result below
3689430782?profile=original
3D Rotatable version
I'm not in the same league as some of the other makers of aerial maps on this site, and have no idea of the accuracy of this map, but was pretty happy with the early results and would like to work on this more to get better results.
my setup is
Airframe - ST Models Discovery Trainer with stock motor and 30A ESC
Arduplane 2.24 with Magnetometer, airspeed kit and xbee - a few lines of code added to output roll stabilisation
Home made camera mount with roll stabiliser
Canon IXUS 50 camera 5MP (this is a very light P&S camera) running CHDK
Spektrum DX 7 2.4GHz tx/rx
2200 mAh 3s motor battery + 1000 mAh 2s battery to power all other electronics via a UBEC (the stock BEC is too small)
I used Mark Willis's aerial coverage spreadsheet to calculate the waypoints before launch and it seemed to produce a good result.You can see the waypoint in the following screenshot
3689430961?profile=original
Cheers
James
  • @Nick - I will try to make it to a PerthUAV meeting. Good to see there are quite a few others doing this locally.
    @Micheal - Nice work on the camera dialog. How will you choose the coverage area on screen?
    @Tom, thanks for the feedback on your service. As far as aerial mapping goes, you would probably need to add a few things to make it really useful for that kind of work. There are high-end, expensive services like Pix4D already in this space, but there is always room for more.
    You would need to add things like an estimation of accuracy, orthorectification and use of control points to scale the image to real world coordinates. You would also need to scale up to deal with several hundred images at once. If you can get all of that to work you could probably charge in the order of a few thousand dollars for an aerial survey result.
    There is also emerging demand for data fusion, combining results of photogrammetry with LIDAR scans and other data sources to improve accuracy.
    A typical mining company here in Western Australia would routinely (quarterly) get aerial flyovers of their mines by a full sized Cessna. The accuracy for this kind of work needs to be ~5-10cm so a combination of LIDAR, photos and control points is used. A lot of this data is used for estimating stockpile volumes, mining limits and the like so needs to be accurate.
    I know nothing about 3D printing, so that may be a better choice that doesn't require such complexity.
    I hope you do well.
    Top question, Michael, it won't well for me when I am in Africa!
    Tom, do you plan on offering and offline version?
    3692295477?profile=original
    I will be adding this screen to the next planner version (might be a bit away). its all working and should provide some numbers to use in the "grid" option of the planner.
    I just chucked some pictures I had hanging around to see how this service compared to photosynth and I am impressed.
    Heres the model https://www.hypr3d.com/models/4eb0662b01b5a3000100001c
    and in Photosynth http://photosynth.net/view.aspx?cid=df2bf33c-c817-4bbf-9a53-8f93659...
    3692295297?profile=original
    It only used half the images I added but then I did'nt select them in any way. I have another little project that I would like to try next in hypr3D before trying the 15km of river that I have images of!
  • Martin,
    CHDK is very easy to set up a trigger with a voltage pulse on the cameras USB.  Just hook this into your APM relay.
  • Good job, James! Thanks for sharing!
    I did the same with my plane, camera and APM this summer. It's great!
  • Nice job!
    Could you explain how to generate the WP from the spreadsheet? I could not understand how it works.
  • excellent work! This really looks great.
  • Nice James. Good to see that you're in the air.
    You'll have to come to a Perth FPV meetup and show off your kit :D
