Measure twice, cut once. Or just take the scapel to it.
3689367549?profile=original
Now the major bodgery has been done I added the propeller (7x4 from previous) and noticed I was 5mm to big for the plane but as it has work my me so well in the passed I though I'd just mod it in. Using the poke and trim method I created a groove for the blade to fit through. Tolerance is pretty high in lateral movement but only 1mm to the bottom of the groove (so if it grows it will catch :D)
  • Thanks Jason. They are on order as TCIII said the same.
    Have you flown an Easy Star before? That tail flexes a lot - try and put a carbon spar in it.
