Click Here!
Features:
-Basedon MediaTek Single Chip Architecture.
-Supply from 3.3V to 5V!
-Dimension:16mm x 16mm x 6mm
-L1Frequency, C/A code, 66 channels
-High Sensitivity:Up to -165dBmtracking, superior urban performances
-Position Accuracy:< 3m CEP(50%) without SA (horizontal)
-Cold Start is under 35 seconds(Typical)
-Warm Start is under 34 seconds (Typical)
-Hot Start isunder 1 second (Typical)
-Low Power Consumption:48mA @ acquisition,37mA @ tracking
-Low shut-down current consumption:15uA, typical
-DGPS(WAAS, EGNOS, MSAS) support (optional by firmware)
-USB/UART Interface
-SupportAGPS function
You can watch it in action here, i got 9 satellites during fly, taking in consideration a 1.3Ghz@1Watt video transmitter very near to it:
The heading and the altitude is not that bad! Soon i will release an easy to solder interface board with EM-406 "like" port.
Do you plan to release the interface board this week?
TCIII
What is the status of the interface board for the MT3329, available soon?
http://diydrones.com/forum/topics/mediatek-mt3329-gps-10hz
Started a thread in the GPS section of the DIYdrones forums.
http://www.gtop-tech.com/index.asp?pid=6&newsID=20
Yes I know it is GPS module and not a chip since Mook can buy your module and desolder the patch antenna and remove the ceramic spacer too, all he will be left is what he is looking( Chip) for I guess :). Trying to help Mook.
BTW , I like to know if the forbidden area is whole of the board under the antenna or is it just the center 2-3 mm point under the antenna where the antenna is soldered to the board? I read your documentation but did not understand this issue/point. Are these( the board that is seen under the GPS antenna module) double sided PCBs? Thanks once again for the clarification.
Remzibi has been using it without the boards for months, without a single problem... He just soldered the wires directly with a nice connector and wrap it! The GPS has a LDO that regulates the voltage... In my board I only use the 3.3V to protect the Backup ram that works with 3.3V only (4.2V absolute).... Without the battery every time you disconnect it will take 35 seconds to start up.... With battery only 1 second (Hot Start).
@Jordi , Without the board it wouldn't matter. and rechargeable things discharge when left alone for some time. So that would not be my best argument in this case against 50 cents battery. Looking forward to see the board in stores soon. Cheers
