Click Here!
Features:
-Basedon MediaTek Single Chip Architecture.
-Supply from 3.3V to 5V!
-Dimension:16mm x 16mm x 6mm
-L1Frequency, C/A code, 66 channels
-High Sensitivity:Up to -165dBmtracking, superior urban performances
-Position Accuracy:< 3m CEP(50%) without SA (horizontal)
-Cold Start is under 35 seconds(Typical)
-Warm Start is under 34 seconds (Typical)
-Hot Start isunder 1 second (Typical)
-Low Power Consumption:48mA @ acquisition,37mA @ tracking
-Low shut-down current consumption:15uA, typical
-DGPS(WAAS, EGNOS, MSAS) support (optional by firmware)
-USB/UART Interface
-SupportAGPS function
You can watch it in action here, i got 9 satellites during fly, taking in consideration a 1.3Ghz@1Watt video transmitter very near to it:
The heading and the altitude is not that bad! Soon i will release an easy to solder interface board with EM-406 "like" port.
What is the status of the interface board for the MT3329, available soon?
http://diydrones.com/forum/topics/mediatek-mt3329-gps-10hz
Started a thread in the GPS section of the DIYdrones forums.
Remzibi has been using it without the boards for months, without a single problem... He just soldered the wires directly with a nice connector and wrap it! The GPS has a LDO that regulates the voltage... In my board I only use the 3.3V to protect the Backup ram that works with 3.3V only (4.2V absolute).... Without the battery every time you disconnect it will take 35 seconds to start up.... With battery only 1 second (Hot Start).
That means i will have to stop selling the modules alone and sell them with the board and little bit more expensive.... So hurry before they ran out...
Also quadroufo has a design flaw... It don't suppose to have ANY circuit under the antenna..... Mine has the circuits away from the "forbidden" area indicated on the datasheet...
Yes, and the store will be close Friday (May 14!), Saturday, Sunday and Monday 17. ;-) I did an announcement a few weeks ago:
http://store.diydrones.com/
1
2
3
of 3 Next
