More Bixler Mods
3689464168?profile=original
A couple of technical and personal delays are going to push out my Bixler's first flight, but I thought I'd share a couple of pictures.
Mike Pursifull suggested increasing rudder area, which seems like a reasonable thing to do.  I used a cardboard photo mailer and glued the edge together with white glue, and used silicone calk to glue it to the rudder.  The result is light and super stiff and about doubles the rudder area.  I used calk hoping it'd be easier to undo if I want to try something else.
Here are the two halves with a notch for the control horn:
3689464036?profile=original
Here's the extension while it's installed:
I also implemented the rubber band and Command hook idea:
3689464196?profile=originalI'm not very satisfied with this solution.  It was too fiddly to install and I'm not sure I have enough tension.
Feedback is welcome.
I also had a minor disaster; one of the crummy aileron clevises broke when I was adjusting it.  I'd like to replace it with something better.  Does anyone have a good option to replace these?  My local hobby store only has larger ones.
  • Marroned and Brian,
    Copying both ideas, my solution:
    Bixler Building - Join/Fixing WingsBixler Building - Join/Fixing WingsBixler Building - Join/Fixing Wings
    Thanks!
  • I switched to a similar solution, though I may need to add some shims to keep the wings from wiggling in bumpy weather.
  • Thanks for sharing, Nice solution.
    This weekend, I decided and put hooks in wings. I so escared about wigs flaw away in air...
    Latter I will up some pics.
    I also use 8mm fixed with epoxy ins wing trench. So, 6mm inside it.
    Here some pics: http://www.rcgroups.com/forums/showpost.php?p=22796390&postcoun...
    Thanks a lot!
    RC Groups - View Single Post - Sky Surfer - aka Bixler See Post #2 & #3 for parts & mods B4 asking
  • 3692531130?profile=original3692531145?profile=originalPlus after the crash I used 8mm (instead of original 6mm) carbon fiber rod. Also the inner diameter is much smaller making the whole rod MUCH tougher (and a bit heavier). I used CF rod from tent found on the field after Woodstock Festival ;-) I had to drill a bit the wings but now it's hard to detach them so this velcro is something extra, not the main thing to keep them together.
  • Nice to hear, Marooned.
    Have you pics of the your building?
    Thanks!
  • Hi Marcelo. In my Bixler I'm using velcro straps to join both wings. So far so good. I'm satisfied with this solution.
  • Hello!
    Brian, nice your post.
    I'm right now build/finishing my Bixler (first model!) and this soluttion to join halves wings, is very interesting. I think in little magneto, but I thik these isn't sufficiente strong.
    Could you please let me know if your solutions works, are you fllying good??
    Thanks in adavance!
  • One of the problems I can see with your rudder mod is your going to be putting a great deal of stress on the rudder during a sharp turn and that protrusion can get messed up in a bad landing.  It will also put more stress on the servos, so if you hear clicking .....
    Also, a good number of people have done this before.I would recommend you use plastic mini hinges covered with blendo surgical tape instead of using the normal foam connection.
    +1 on the HK control horns... that's what I use on my HawkSky clone.
    I've seen lot's of pictures on RCGroups where people run the rubber band under or over the plane, it seems to work well.
    Here's how I extended my EZStar rudder.  There's a card on each side of the rudder.  The cards are thin plastic, much lighter than a credit card.  As you can see it's made with extra care!
    a3966577-201-MarHars%20ES%20Rudder%20mod%20IMG_1641.jpg?width=500
