This is my first attempt at building an ArduCopter. I started with franticly searching the web for parts. I had no idea what I was looking for, but I was looking. Between DIY Drones and AeroQuad, I was able to come up with a list. I have a little background with the arduino. But nothing like this. Mostly would work with LEDs, LCD screens, and Temp sensors.
Ok on with the build. Here are some pictures of what I have so far.
I have a thousand questions, that I don’t even know I need to ask yet.
Thanks to all on this site....
Now that I have got that done, I thought it was time to do some testing. So I tied it to a 20lb dumb bell in the middle of my living room. Armed the motors and slowly applied power. It seems like the back motor is stronger than the rest, I even calibrated that one again.
I am using an old 72MHz Futaba T6XH. So I only have one extra channel. I am wondering if I have it in the right mode.
It should show around 460 when at level. Why? Answer is rather simple. It's due earth gravity. Accell measures gravity changes and when It is level and not moving x/y axis are at zero but due earth is pulling us towards it's center with aproximate force of 1G. Accell what we use on OilPan shows 460 at 1G. This walue changes a bit on different locations. Best way to find it is to calibrate x/y to zero and then told you quad 90 degrees. And you should see 460ish value on your X or Y axis depends on which way you tilted IMU.
So after that you can make Z calibration correctly :)
2047,2025,2457,1673,1679,1679,1578,2843
OK. Now I got exactly the same here. ;)
About Z accel... It's weird... Do you read 0 with it static on the table?
It's exactly what you will read on current version because the pitch is inverted.
For starting to understand the sensors, you need to know that gyro reads only the quick and instantaneous angle changes and returns to 0. The accels are more lazy but continuing to read the actual angle. So when you have a cooperation between them, you achieve the best of two worlds.
If you go from the "Flight Data" to "Artificial Horizon" you can see that all is perfect, except by the inverted pitch (the team is correcting it right now).
This is what I get holding it at 80 Deg
1
2
3
of 3 Next
