This is my latest multirotor, it was made entirely on a Laser cutter every single part (but the electronics)
The camera Gimbel is also laser cut and the entire thing is my design.
Just thought i would like to get your guys thoughts on it.
~A few notes on the design
The arms are raised above the CG to give stability in stable hover and decent.
The motors have a 10% outwards tilt this gives a higher flight speed by allowing a larger tilt in flight, it also gives stability when descending or ascending as the motors give a minute amount of horizontal control.
the under mounting of the motors give a around a 9%efficiency increase as the air is not thrusted onto the arms.
the overall result is a inherently stable design, in one of my recorded flights the motors are completely cut for a few seconds and the copter glides down as the motors auto rotate, it didn't flip or roll or oscillate, it simple glided down.
here is move video footage
  • Amazing, you built it upsidedown by mistake and the APM is so good it still works. ;-)
  • weighed in at a bit over 4kg with gimble and batteries
    use 8 kinda crap motors
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
    Donkey st4010-820KV 194grams
    4 x 300mah Turnigy batteries 239grams
    40amps ESC's 40grams
    so 1.554 KG on the motors + 320 gram esc's + 956 grams on batteries + 500grams all in for wires, apm telemetry gps props gimble
    Apm 2.5
    so 3.3KG just from the electronics
    this plus the 900gram frame gives 4.2KG
    but it has a huge amount of power, it rockets if i want it to.
  • Nice aerodynamic catches,, I was figuring some octopyssy style 3d printed frame like this.
    Cleaner to push air, and tilt is good idea.
