Hi eveyone,
I received my first order from Batch PCB yesterday, it was my first foray into an actual drone. I designed the PCB myself, from scratch, so I was pretty proud when I plugged it in and it started working. It has been designed around the ArduIMU+ V2, the Locosys LS20031, an OpenLog, and of course, an Xbee.
The board is just a small step up from the Proto-Shield (SparkFun) version I built a while ago, except it has some capacitors, filtering the 5V power supply, and a voltage monitoring circuit.
I built it in the late hours of the night, and had it running my home-made auto-pilot code by 2am. Right now it has the same functionality as the proto-shield v1 I built before, except that the GPS is fully functional, and it is correcting the aileron and elevator values, with gains, to the required roll and pitch angles.
BTW if anyone has any constructive critisism, feel free!
I have already learned a few lessons from making this board, and V2 is already on the way.
Tell me what you think!
I was thinking about that, but this is a science fair project, so I couldn't to use a commercially available product (and code) to start with. Besides that it was a real learning experience, so i'll have a little bit more knowlege for my next project.
maybe I'm wrong, but why don't you just use APM?
Arduino Mega is heavy and not really optimized for drones.
How about some info on components on the boards.
