3689598322?profile=original3689598300?profile=originalWe have finished new board NEO-M8N + Compass
NEO-M8N breakout board features:
  • 72-channel u-blox M8 engine GPS/QZSS L1 C/A, GLONASS L10F, BeiDou B1 SBAS L1 C/A: WAAS, EGNOS, MSAS Galileo-ready E1B/C (NEO-M8N)
  • SuperSense Indoor GPS, -167dBm
  • On-board Ultra low noise 3.3V voltage regulator and RF filter for noise blocking
  • USB, I2C (SDA,SCL) and Uart (Tx,Rx)
  • Dual band GPS and Glonass antenna
  • u-center GPS Evaluation Software
  • Extensive visualization and evaluation features
  • Supports AssistNow Online and AssistNow Offline A-GPS services
  • 1 TTL UART port, 1 I2C port,1 USB port
  • Time pulse LED
  • Flash memory for firmware upgrade and settings inside in the module (can save setings without battery)
  • Battery for HOT module start
  • Build-in HMC5883L Compass
  • Dimensions: 50x50 mm hole distance 45x45mm
  • Weight 24 gram
  • Fully assembled and ready to use
