New 3DR autopilot: Pixhawk Mini
The wait is over! We are proud to introduce the next generation 3DR autopilot, Pixhawk Mini. Pixhawk Mini is an upgraded Pixhawk designed in collaboration with HobbyKing and optimized to run the Dronecode PX4 firmware stack and QGroundControl multi-platform ground station (Windows, Mac, Linux, Android, iOS).
For just $199, Pixhawk Mini includes autopilot, GPS, and all the cables and connectors needed to get started building DIY quads, planes, rovers, and boats.
What's improved over Pixhawk 1?
  • One third the size--dimensions reduced from 50 mm x 81.5 mm x15.5 mm to 38 mm x 43 mm x 12 mm. Smaller airframes can now operate autonomously without making sacrifices for the Pixhawk footprint.
  • Rev 3 STM32 processor allow for full utilization of 2MB flash memory. Pixhawk Mini operates at only 50% compute capacity, 40 percentage points lower than the original Pixhawk. There is significantly more overhead available to run custom code.
  • Improved sensors, including both primary and secondary IMU (MPU9250 and ICM20608, respectively), lead to much better vibration handling and increased reliability.
  • GPS module included--Neo M8N with quad-constellation support and upgraded HMC5983 compass.
  • Micro JST connectors replace DF-13. We can all breath a sigh of relief.
  • Integrated piezo speaker and safety switch
What's improved over Pixfalcon?
  • Again, improved sensors, including both primary and secondary IMU (MPU9250 and ICM20608 respectively) for much better vibration handling and increased reliability.
  • Dedicated CAN port for UAVCAN applications.
  • Includes 8-channel servo output board for planes and other vehicles requiring powered PWM output.
  • Includes I2C breakout board for a total of 5 I2C connections.
Pixhawk Mini features an advanced processor and sensor technology from ST Microelectronics® and a NuttX real-time operating system, delivering incredible performance, flexibility, and reliability for controlling any autonomous vehicle.
SPECIFICATIONS
  • Main Processor: STM32F427 Rev 3
  • IO Processor: STM32F103
  • Accel/Gyro/Mag: MPU9250
  • Accel/Gyro: ICM20608
  • Barometer: MS5611
  • Dimensions: 38x43x12mm
  • Weight: 15.8g
GPS Module: ublox Neo-M8N GPS/GLONASS receiver; integrated magnetometer HMC5983
  • Dimensions: 37x37x12mm
  • Weight: 22.4g
Interface
  • 1 x UART Serial Port (for GPS)
  • Spektrum DSM/DSM2/DSM-X® Satellite Compatible RC input
  • Futaba S BUS® Compatible RC input
  • PPM Sum Signal RC Input
  • I2C (for digital sensors)
  • CAN (for digital motor control with compatible controllers)
  • ADC (for analog sensors)
  • Micro USB Port
What’s Included?
  • Pixhawk Mini Flight Controller
  • GPS with uBlox M8N module with
    • Concurrent reception of up to 3 GNSS (GPS, Galileo, GLONASS, BeiDou)
    • Industry leading –167 dBm navigation sensitivity
    • Security and integrity protection
    • Supports all satellite augmentation systems
    • Advanced jamming and spoofing detection
    • Product variants to meet performance and cost requirements
    • Backward compatible with NEO‑7 and NEO‑6 families
  • Integrated Power Module (up to 6s batteries) and power distribution board for quadcopters
3B3FytiZ9aBC7N1xM9mkVE2LtETaxoqrgFAo_5Dp2hetpbvuYqCWjy6GkC5PnREW1XekrloCNwg-laNm6sI3ERq6DHl5Bx3aPNzdFNVyQd-_MczJwSIpd-TcgCVlZ4il1SU5jUjc
  • 8-channel servo output board for planes and other vehicles requiring powered PWM output.
  • Cables
    • 4 pin I2C cable and breakout board
    • 6 pin GPS+Compass cable
    • 6 to 6/4 ‘Y’ adapter for additional I2C devices
    • 4 JST to 6 DF13 cable for legacy telemetry radios
    • External safety switch cable
    • RCIN cable for PPM/SBUS input
    • 8 channel RC output cable
    • 6 pin power cable for included Power Distribution Board
OPTIONAL ACCESSORIES
All available here
3Im6wXwv4oHZ81nl6aARLkPJJNnyj6-ibPJ4lew51mPvtg_hBbic67qH2WuCSHKikEQEXXTXR2pgWF8HAr2VGdYod6kFjPntRJnivhntxCCbxulsYDn6WhyxLrdcGewyyJBlNatv
  • Awesome! I'll give it a try. Thanks
  • Try latest 3.5 beta?  I vaguely remember they might have added support for it recently
  • Yes, It does not recognize the hardware correctly. I get a border error no l3gd20 found.
  • Try arducopter?
  • Another problem I have is with the motor assignments. Hexa X ESC LEDs usually light up green on one side and red on the other. I have a couple out of place and no motor test so I don't know how to check it. However, if I lower the Hex to one side the motor on the low end spins and the ones on the high end stop. . If I lower two motors they both spin so it seems to be controlling the right motor. Other than that I'm just not sure it's correct or how to check it.
    1, 2 and 6 are red and the others are green.
    regards
  • Anybody try to fly a copter with one of these? I have had nothing but problems trying to get it to work. Not sure what the problem would be but the motors only spin when they are below center. Something wrong with the PX4 stack but I can't find anything posted about it other than problems.
    Any suggestions would be great.
  • I second the above, schematics or more information is needed to hook a RDF900+ up.  Customer support only has the manual which has no technical information.  They even went so fr as to say: "...All you need to know about the Pixhawk mini is on the manual."  I have searched the internet high and low for Pixhawk mini technical information and pin-outs, I have found nothing.  Any help would be greatly appreciated.
  • I came upon this looking for a replacement for my now dead Pixhawk.  Is the new Mini hardware open, will there be a schematic available to help with troubleshooting and integration with other hardware?
  • This is really awesome, I'm glad the hardware innovation continues on the pixhawk family.  I'm a huge fan of pixhawk and the PX4 software stack and the rapidly growing family of great tools for managing these drones.
  • Yes!
