This is the latest Flying Multicopter Camera system. It uses the Panasonic HDC-TM900. The arms are on rubber mounts and only move if there is any vibration. The motors are Pulso X2826/12 Kv 760 they have 5mm shafts and are three bearing. They run very smoothly compared to the MK3538's. Three axis of inner stabilisation on the camera mount plus three outer on the model itself. It is made from balsa, plywood and insulation foam covered with epoxy resin and lightweight cloth. Strong, light and it floats. Rock steady imagery, even when zoomed to 80X. Still waiting to get the latest code for the FC. The only bit that I really need help with.
A lot of that is in the camera but the mount itself can hold around .003 degrees. I have been banging on about how this is done with mems technology but nobody listens.
The weight changes from day to day as I try different camera set-ups but each motor can lift over 3 Kg. so it is not an issue. props are 14x4.7 two or three blades. I am using the Gentles stuff on my 550D camera. I like the Panny because of the stunning quality and the weight saving. Working on some video that will explain a few more things but as usual I don't have enough hours in a day.
I don't have vibration issues, A lot of effort went into isolating it at source. The camera works fantastically well. I also use and like the Canon 550D.
2
3
of 3 Next
