Here's an interesting lifting body design for a MAV (Micro Air Vehicle) by Theiss Aviation. Its autopilot uses thermopiles, so you won't be using it indoors.
From Robot Living:
"The new model TIC costs around $6,000 and can potentially be launched from the trunk of a car. It contains chemical as well as biological sensors and could also be outfitted with a small color camera. These vehicles are designed to fly in ventilation shafts, tunnels, small quarters and even dense woods. Using a 72 MHz radio, the TIC has a range of 1.5 miles and can be run in basic radio controlled mode, auto assist mode or completely autonomously.
Theiss Aviation is now seeking to sell these aircraft to police departments, search and rescue crews or other emergency personnel.
Unfortunately the FAA seeks to treat these tiny craft just like regular planes.
The owners of a TIC must register the aircraft with the FAA and give 60 days notice of flight plans to the FAA."
Here's more about Shawn Theiss, from Fortune Small Business, discussing the regulatory problems for UAV entrepreneurs. We should have him on as a podcast guest!
From FSB:
"Here's what every TIC owner must do to be certified: submit detailed drawings of every part of the plane, wait three months, answer any FAA questions, then wait another month for a registry number.
Finally, the tiny drone must be cleared to leave the ground by FAA officials every time it flies. For drones, most flight plans must be filed 60 days ahead of time.
"The size of the unmanned air system doesn't matter," says Alison Duquette, an FAA spokesperson. "Any size could pose a danger to private or commercial planes." Also, officials point out, the TIC is too small to be tracked via radar.
Critics argue that the agency is being squeamish about a technology that would help public safety more than harm it.
"Small unmanned planes are not rocket science," says Dave Nestic, entrepreneur in residence at JumpStart TechLift Advisors, a Cleveland incubator that studies the propulsion market.
Theiss, stymied in his bid to sell to anyone but the military, is still fuming. The FAA is "not aviation-minded," he says. "It's regulation-minded."
@gary - ITAR looks very scary. I had no idea they even existed! Seems they could arbitrarily come down on anyone at any given time over anything. Are they working with the FAA to clamp down on private companies' use of UAVs? Or is the "they" just regulations and not a separate body of government? Either way, this reminds me of something Burt Rutan told me ... "The laws of this country are harder to overcome than the laws of physics".
Regulatory roadblocks are just fuel for the open source fire. If they're going to make life hard for the pros, the amateurs will rise to fill needs. Once these projects are open, actual production can happen anywhere, with the "atoms" side of the process migrating to countries with the most welcoming regulatory environment. It's a global market and I for one don't care what country things are made in as long as the technology is available to users everywhere.
It may be that they use different sensors for flight assist mode vs full autonomy. From the page linked above: "This option uses a simple onboard autopilot assist system with thermal imaging sensors for roll axis and
pitch axis."
I love the FAA's response. Don't they realize that airplanes don't fly below 500 feet? And my neighbor hitting golf balls into my yard is far more dangerous.
From what I understand from some folks "in the know", the big boys don't want private companies cluttering "their" skys. Nothing to do with safety... but that's the excuse. We'll see how long they can hold the flood gates closed.
Are you sure that uses thermopiles? The ground station software running on that laptop is Procerus' Virtual Cockpit for the Kestrel autopilot (http://procerusuav.com/images/large/img_vc-preflight_lrg.jpg). In which case if it uses the Kestrel I would expect it to cost much more. Either way, it's a very cool design.
pitch axis."
1
2
of 2 Next
