T-MOTOR MN Series Motor Upgrade: Thrust Level Upgrade (MN11-13 Series) — Now Worldwide!
The upgraded thrust level of the T-MOTOR MN11-13 Series motors is now available worldwide. If you’re building or upgrading a heavy-lift UAV, this release is designed to help you push more demanding propulsion performance with confidence. Recommended thrust range/motor: 1–37 kg Designed for applications where users need higher thrust capability, including logistics, cruise, and cleaning drones—and now even more for heavy-lift propulsion setups. 🔧 Why MN11-13? -Higher thrust performance for demanding missions -Built for heavy-lift multi-rotor propulsion needs -A strong upgrade path for existing T-MOTOR users familiar with the MN series 💬 Need a complete drone propulsion solution? We can help with propulsion options across: Multi-rotor Fixed-wing VTOL For more complete drone solutions,
contact: marketing@tmotor.com
For product information: https://uav-en.tmotor.com/Multirotor/Motors/navigato/
