After XAircraft successfully launched new four axis aircraft X450 and X650 last year, its new generation aerocraft will be released on 15th July. This new type quadcopter has been named officially: X650 Value (Best Value Version) and X450 Pro (Enhanced Version). X650 Value has two versions: 4 propeller(X4 model) and 8 propeller(X8 model). And plus “-4″ and “-8″ in front of the name for distinction, for example, X650 Value-4 is 4 propeller, X650 Value-8 is 8 propeller, X650V4 and X650V8 for short.
This new generation XAircraft X650V4/8 and X450 Pro will be over-emphasized on aerial photography, which has more stable and positive fly performance, and can stay in the sky for longer time, with its stronger load capability and distinctive external appearance. We believe it will definitely become your indispensable aerial photography sharp weapon that let you fondle admiringly. In the meantime, XAircraft will continue to manufacture parts for old X650 and X450, and also provide the upgrade kit, in which you can upgrade the old version to the new one, save the cost of upgrading in maximum limit.
For X450 Pro
It is positioned for entry level player which has a higher drop number fuselage, provided simple aerial photography function and a simple GOPRO mounting plate(Simple Camera Mount). Besides, it has the same flight control system and power driven system as X650(brushless motor and ESC). 10 inches propeller and brushless motor is a specially made structure, used for lowering the center of gravity.
For X650V4
Cheaper than old X650, it has adopted a new designed fuselage with more cool external appearance and practicability, can be quickly folded. The fuselage cover can also be quickly removed and installed. The fuselage of and X650V4 and X650V8 are made of carbon fiber material, the Mounting Plate, Motor Mount, Landing Gear are made by high strength plastic. The camera mount and battery can be slide on the crossbeamis which means you can adjust the center of gravity easily according to the weight of photographing device attached.
For X650V8
It has adopted the same fuselage, flight control, brushless motor, ESC and propeller as X650V4. That is, X650V8 has all the outstanding characteristic of X650V4, the only difference is X650V8 has 8 brushless motor, thus can provide stronger load capacity. X650 V4 user only need to order other 4 brushless motor, 4 ESC and 4 propeller, to upgrade X650 V to X650 V8 immediately! Of course, if you want, Value-8 can also be degraded to Value-4, in this way, it can help save more electricity, get more flight time.
X650 Value series are all using the “x” shape flight style, cannot use the “+” shape flight style (however the flight control in itself support).
In addition, the development of XAircraft’s biaxial camera mount has finally come true; its photography effect stands in the first-class level in the small aircraft. This biaxial camera mount has two models, CMGOPRO-TP (two axle control including 2 servos) and CM130C-TPS (two axle control including 3 servos). The CMGOPRO-TP is specially designed for GOPRO camera, with lighter weight, fit for GOPRO camera user. The CM130C-TPS is mainly designed for the card camera and the EVIL(Electronic Viewfinder Interchangable Lens), but at the same time it can also install the GOPRO camera, has a extra steering engine to controll the shutter, can also be used on the old version X650C and X650G, but can’t be used on X450 and X450 Pro.
Note: The transmitter,receiver and battery are NOT INCLUDED, you need to prepare a 6-chn(at least) transmitter and receiver, 11.1V or 14.8V/15C/2200mAh polymer lithium battery pack and assemble X650 youself.
The GPS, compass, biaxial camera mount are optional accessories, customers can select according to their own requirement. There are OSD, light and power supply for option in the future.
X450 Pro Standard Configuration(Price:$399):
- 1x X450 Pro Fuselage
- 1x GOPRO Mounting Plate
- 4x new type External Rotation Brusless Motor
- 4x 10A Brushless ESC
- 2x 10 inch Clockwise Propeller
- 2x 10 inch Counter-Clockwise Propeller
- 1x XAircraft FC1212-S Flight Control Unit
- 1x XAircraft AHRS-S Attitude Sensor
- 1x XAircraft USB-Link PC Linker
- 1x XAircraft Flight Control Management(Parameter Adjustment) Software
X650V4 Standard Configuration(Price:$620):
- 1x X650V4 Fuselage(Landing Gear,Carbon Fiber, Plastic)
- 1x X650V4 High Strength Fuselage Cover
X650 Value-8 Standard Equipment(Price:$720):
- 1x X650V8 Fuselage(Landing Gear,Carbon Fiber, Plastic)
- 1x X650V8 High Strength Fuselage Cover
- 8x New Type External Rotation Brusless Motor
- 8x 10A Brushless ESC
- 4x 10 inch Clockwise Propeller
- 4x 10 inch Counter-Clockwise Propeller
- 1x XAircraft FC1212-S flight Control unit
Optional Accessories:
- XAircraft GPS+Compass(Price:$247)
- CMGOPRO-TP or CM130C-TPS Biaxial Camera Mount(Price:$250)
- Uniaxial Camera Mount(Price:$79)
Additional accessories needed for flight:
- At least 4 channel remote controller(suggest above 6 channel)
- Above 11.1V or 14.8V/15C/2200mAh polymer lithium battery pack
- Lithium battery charger
