3689679301?profile=original
The Ninox is a compact aircraft capable of carrying action cameras (GoPro Hero, GoPro Session) and small mirrorless cameras (Canon PowerShot, IXUS, Sony WX,...).
It is equipped with a Pixhawk autopilot for fully automated flight, from takeoff to landing. Control and in-flight monitoring are available via radio telemetry link.
Endurance of 30 minutes is available with a small battery.
The durable airframe made of durable EPP material. The hinged wings (100cm, 36 inches) can be easily folded for transport in the included aluminum case. Setup takes less than 3 minutes.
Complete systems available from € 1,680 (excl. VAT).
- Made in Germany -
  • Hi Franz,
    Thanks for the file!
    I'll contact you soon for more information when i will buy the others pieces to terminate my Ninox!
    Sylvain
  • Hi,
    of course, here you get it: https://www.magentacloud.de/share/pyt0tv.ttl    => NINOX_0316.param
    MagentaCLOUD
  • Hi Franz,
    Is it possible to give the parameters of PX4 for the Ninox?
    I've this fixed-wing and i want to parameter the PX4.
    Sylvain
  • Thank Franz ... The wx220 not appear on camera compatible relationship with the trigger cable, but is guaranteed to work?
  • Sony Multi-Terminal RC Shutter
    http://www.flytron.com/rc-camera-shutters/307-sony-multi-terminal-r...
  • which trigger cable would be ideal for this style wx220 have a similar camera and would like to use in my drone, would have to perform some internal change in wx or so the cable is enough to make the shots. Any circuit to ride this cable? where I can buy.
  • Hi,
    correct, to integrate the Sony WX220 or similar cameras with the Pixhawk you need a trigger cable.
  • Very Pleasant Franz ... the camera that is embedded in Ninox Sony WX220? I wonder how did the integration with pixhawk is through some trigger cable.
  • Hi,
    you have the possibility to change the position of the equipment to maintain the COG. With our battery LiPo 3S/2200 you can fly approx. 30 min. You can also use a second battery or one with higher capacity. The cruise-speed is approx. 50 km/h.
  • 3702164877?profile=originalHello, NINOX is developed for cameras up to 200 gr. The Sony α 5100 is alittle bit to heavy, for this type of cameras we have the UAV MAJA.
