NIR Images in the Makgadikgadi
3689566110?profile=original
Hello,
I was touring the makgadikgadi this December in Botswana and here is some interesting Raw NIR images I have taken.
Here are some boabab trees in the NXAI salt pans
3689566032?profile=original
3689566133?profile=original
Here is of the salt pans
3689565981?profile=original
Here is of an elephant covered in mud, note the previous images containing people where the people is a purple as well and then look at the elephant covered in mud.
3689566148?profile=original
3689566153?profile=original
Here I took an image with a healthy bush next to a dead bush, see the difference.
3689566174?profile=original
You can go and download these images and process them at http://www.infragram.org/ and see the NDVI and IR Image of these images. We will be shortly adding this camera to one of hour talons to do some aerial photography.
  • Tutorial from link above is very good, the software is not Photoshop, but GIMP (open source).
    What is mentioned in tutorial is you need to have 2 images in order to produce the NDVI images. You need the NIR and also the visual RGB. Then but combining those 2 (based on formulas add, substract, devide), then you obtain the NDVI.
    Now I am little confuse how you can obtain the NDVI with just NIR image as input, can you explain?
  • Also Photoshop can convert NDVI images
    https://www.youtube.com/watch?v=-nNnWEHNO_w
  • I did find a tool (Global Mapper) who can process NDVI images, but not tried yet. I believe they have a trial version to download. Did you use this software for NDVI images?
    3692917836?profile=original
  • I see their services is a bit offline. I am not sure what other tools there are to convert these images.
    Here is a php script if you know how to use it
    http://forum.worldwindcentral.com/showthread.php?2869-NDVI-amp-NIR-...
  • I did try converting of of your NIR image to NDVI, using the link provided, in order to make visible the photosynthesis of plant, but when it start conversion (after upload), I got repeated time next message below. Any idea?
    "The page you are looking for is temporarily unavailable.
    Please try again later."
  • One of the main uses of NIR images is a type of post processing where you can monitor the health status (photosynthesis) of plants. See the last photo.
    What's the purpose of NIR images? They just look pink to me :))
  • Check out this video in the makgadkgadi I took with the multirotor
    http://www.diydrones.com/forum/topics/makgadkgadi-tour-with-my-mult...
  • @Criro I used a sony cybershot 10.1 megapixel for this (I recommend the SX230HS) and I removed the IR filter and in the same cavern I placed a blue filter from public lab.
    One can play around with the images from this tool http://infragram.org/static/sandbox/ , here is a little blog regarding this http://www.publiclab.org/notes/cfastie/11-12-2013/red-filter-rising
    @Petrus I flew at kubu island and all over the makgadkgadi nature reserve with the new 433mhz telemetry modules (wich was connected to a tablet) and 5.8ghz 500mw FPV  and had no issues. I am busy uploading the videos to youtube and will post it as soon as possible.
    One c
