Discovered a method to provide an alternative 3.3V for powering the onboard Baro, Accelerometer, Compass when the built in 3.3V regulator TPS79133 fails.
I documented the details and equipment required here
http://flight.farbird.com/2014/02/repair-blown-33v-regulator-on-ardupilot.html
No solder method to provide alternative 3.3V source to the onboard sensors.
The article says:
Be VERY careful with step 3. If you pry a component of the PCB board, you risk pulling the PCB solder pads of the board also. Doing so will make it more or less impossible to solder on a new 3.3v regulator later if you want to.
Awesome la Franklin...
