Octocopter - basic to start
3689540726?profile=original
3689540819?profile=original
Have been building up a basic octocopter (already have other quads) based on cost looking to eventually go to a nice frame.
Whilst the Hobby King frame is nasty and cheap it is a start and for under $40 it seems OK (yes it has its problems)
My intention is to figure out best prop motor configuration for longer flights, etc.
Hobby King Octocopter frame - landing gear is woeful!!!
Turnigy 35-36 910kV propdrive motors with prop drive adaptors
12x4.5 props - at present
30 Amp Turnigy plush ESCs (wiring needs tidying)
2 x 3300 Turnigy 4S batteries in parallel
HK antivibration foam (orange) under a range video mount with APM 2.5 on top
Waiting for external compass and to mount GPS at present
Turnigy 9XR radio, FRSky module and receiver
3DR radio link
Intention is to put my brushless gimbal with Sony NEX5 on it for some video just for fun.
Have not done a compassmot or compass calibration to date but did actually fire her up and see what happens.
Jumps in the air alot more aggressively than the quad and the noise is a bit frightening, response to throttle was a bit more sensitive than expected. Was really stable in windy conditions during initial tests. Remarkably more stable than smaller quads I am used to.
Have not looked at tuning so far as only preliminary tests on stabilise.
Anyone looking to do the same thing happy to share experience or any advice or considerations are welcome.
Cheers
Brian
  • Thought so. Dubro markets the same type of material in a few different thicknesses. HERE is one seller. I picked mine up at the local hobby shop but probably could also find it at a fabric store or sewing department.
    I am trying a section of it on my 2nd scratch build, documented on Instructables HERE. Double stick 3M tape holds the foam to the APM on one side and to to the upper most (for now) plate.
    There has been robust and lively debates on vibration preventing/mitigation on other threads. I hope to maiden the 2nd build soon and will take a look at the logs and compare the results to my rigidly mounted APM2 on my 1st scratch build. That aircraft is documented in my blog section HERE.
    Build on! Fly often!
    -=Doug
  • Big build.
    Is that a slab of foam rubber under your APM mounting plate?
    -=Doug
