Dear Friends,
two years ago i developed a closed source Brushless Controller. It's based on ATmega 8 and support i2c,PWM,Serial Port. The ESC support until 20 Amp and the electronic is present a shunt resistor to evaluate the quantity of energy that the motor need in realtime.
So now I would to port a Arduino bootloader to this board and develop an opensoure code for it.
But i need help for this project ... There're some people that would join me in this project ? That's is good choice for Multipilot 2.0 / Ardupilot 32 platform.
Regards
Roberto
This is the link to forum thread: http://www.virtualrobotix.com/forum/topics/open-source-brushless
It is open source, mostly based on MatrixPilot code for UAVDevBoard.
It would be nice if the AP32 CAN and UDB CAN spoke the same language. Do you have a definition for your CAN protocol? I now notice that you have some CAN based product, even if it is not open source.
Hi Matthew ,
but your project is OS or Closed source ? The MP 2.0 / AP 32 will be CAN Bus ...
Roberto,
Good idea to add CAN as an alternative to I2C.
I have been running a radio and servo interface board connected with CAN:
http://groups.google.com/group/rc-servo-interface
CAN is bomb proof. I run it on plain servo wire at 500kbps with no problems. I cant say the same for I2C.
Unfortunately I cant help you with the Ardu code since this project is dsPIC based.
@Robro, excellent. The information i found is on the parrot shopping site. Look at the motor page and it has the description. I will keep an eye on your site. I am also following this site http://embedded-software.blogspot.com/
@NS Rana,
I'm in starting phase of open source project , now the code is not yer released , today i open on google code ArduEsc repository .. when i have some time i start to populate the wiki.
@Randy,
I love i2c ESC i don't like pwm ESC . My idea is to support a CAN bus ,too on my OS ESC. Actualy I know that pwm ESC not reply his status instead i2c esc as MK esc reply : Voltage, Ampere , Temperature but not speed of motors. I would like to implement in my protocol speed too.
@Fab
where you found info about Parrot ESC ? I write same Hack for parrot , you can found more info in my blog thread :
Parrot Hack
very nice. there seems to be a lot of people playing with the parrot ar drone cpu board (in larger frames) at the moment. Especially since it became open source. Would adding a 10bit or 12 bit adc to your board allow for an easier replacement of the parrot motors?
Description of parrot motor/esc
The motor is attached to its electronic controller which has been specially designed for the AR.Drone. An 8 bit low power microcontroller and a 10 bit ADC control the speed of the motor
