- A soldering iron and solder
- A FTDI cable (DIY Drones cable recommended) to program the board.
- Helium (Available in the balloon kits available for $18 at Target, or a larger tank from Amazon)
- A 7.4v LiPo battery (any other one of that approximate size and capacity will do, as long as it's under about 35-40 grams)
- A balancing charger (This one, with this power supply, will do the trick and is inexpensvie)
- If you want to use RC mode, you'll need an RC system with at least three channels. Any will work, starting with simple systems such as this one. You''ll also need two female-to-female RC cables.
- A 9v battery for the ground beacon
- Double-stick tape to attach the board to the gondola
- Velcro tape to attach the gondola to the envelope
- Superglue
I looked at moderndevice and they have stock, but seems that I solder a few jumpers to get it to 3.3V.
http://moderndevice.com/phpBB3/viewtopic.php?f=16&t=166
2) Not sure; mine hasn't arrived yet.
Couple of questions:
1) For the Sparkfun board, should I order 3.3V or 5V?
2) You referenced that Zippy battery which needs a different connector. Which connector does it need? Just want to make sure my online order is complete when I do this shortly. Thanks.
Should I hold out for the online pack and charger, or is it doubtful that I will ever drain the packs far enough to make unbalanced cells a problem?
The lifting capacity of the envelope is around 130-140 grams. The gondola with recommended battery is around 90 grams, so you've got a bit of extra lifting capacity if you want to add stuff, like higher-capacity batteries or video cameras.
1
2
3
of 3 Next
