The SF30 laser range finder module has been designed to detect all kinds of different obstacles from a moving UAV. The most difficult obstacle to detect is an overhead power line because of its small diameter and dark color giving it a very small "laser cross-section". Add into this mix the issue of moving past these lines at speed and the real magnitude of the task becomes apparent.
In this test we drove under 5 groups of overhead power lines at 60km/h with the SF30 pointing directly upwards into the bright African sky. We used a laptop to record the results and limited the update rate to a relatively slow 1144 readings per second so that the USB comms and file storage could keep up. Measurements were taken in "snapshot" mode, meaning no averaging or filtering, and the resolution of the SF30 was set to 0.25m
Data was logged using the LightWare Terminal app and the objective was to detect the presence or absence of the overhead power lines. Graphing the results shows the five groups of cables as hoped for, and we labeled these 1 to 5 from left to right:
The first surprising result was that the SF30 was not only catching the main power lines, but it was also picking up the static lines at the top. This is a much thinner cable that is used for lightening protection. We were also surprised to see that the height above ground of the cables varied quite a lot between the pylons and even within a group on the same pylon.
When we zoomed in more closely, we noted a strange thing in some places in the data:
The first group of results near the top of this data set were from the static line but the main line appears near the bottom as two distinct groups of data. So we drove back to the site to check out this result and here's what we saw:
The main power lines appear to be in pairs when viewed from below and you can clearly see the static line just off to the left (we were driving from left to right under the lines).
We then examined more of the data and found another unexpected result in some places:
Here we could see three sets of data from the main power line. So back we went and took some more photos:
The power lines on some of the pylons were in groups of three. There were in fact two pylons with the three strand configuration. We found that pylons 1, 2 and 5 had groups of two power lines whilst pylons 3 and 4 had groups of three power lines.
We were blown away by the ability of the SF30 to capture such detailed information about the overhead power lines, even though it was running relatively slowly. In a real situation, the SF30 can take 36633 readings per second and would get more than 200 readings from each individual power line when traveling at 60km/h. You can find more information about the SF30 here.
@Gagarien - thanks! I'm sure you recognize the type of overhead lines :)
Wow Pretty amazing. Well done
@Elios, using lasers for vehicle safety has been a long standing project for many companies. It is not an area that we want to get involved with simply because it involves a lot of regulations. However, we have done tests without using automatic controls and there is no doubt that it is a superb solution, especially at low speeds during rush hour traffic when concentration levels are low.
@Randy, the performance of the SF30 continues to surprise us!
Good to see the SF30 is so accurate.
Hi, Can we use this laser in the real car to avoid accident? it will warn us and can stop the car?
