Maybe someone has encountered a small scale parachute ?
I'd like to add a safety parachute to the Arducopter !! help me decide....
As part of the project is to use an expensive DSLR on the copter,
My GF said i must have some kind of emergency parachute... after joking at it, i thought deeper -
I'd rather feel much safer having a parachute as backup to all electronics (even though i plan on 6 or 8 motors)
Just imagine an emergency button that will immediately turn off all motors and shoot a parachute.
questions:
as parachute takes some time to open (=some free fall height), the benefits are sure and obvious for a 100m fall.
but if i'm around 5m above ground, (which can still be nasty to the DSLR) - would i have enough "falling time" to open the parachute and having enough braking force ?
think i better make one by myself ? is it rather simple as cutting and connecting wires to a cloth,
or it is more complex design that i could hardly achieve and i better get a ready one ?
i came across this as the only parachute i could find:
It looks sturdy and well balanced & stuff... it's totally affordable !
they say the 40" version has 7KG resistance. i'm safe on this side, i dont want a much bigger one.
how about the opening technique ?
i could stuff it in a small plastic tube attached to the top of the dome, using a small solenoid or servo to kick it out...
how do i ensure it opens reliably ? i guess it depends on the folding inside the storage tube...
but do we realy need parachutes ;)
just look at the vid where all engines are out at 700m height (and stayed disabled till the ground):
https://www.youtube.com/watch?v=ZkO-nhApgVA
@Martin-
right, but then i have to add 4 small relays (or 2 double pole) to switch the signal off the APM.
i've seen a warning somewhere to NEVER disconnect an ESC from the APM while running. (that could damage APM)
I really prefer the electronics disconnecting option...
i guess i will have to experiment what happens to the ESC in that case...
I think of getting this one.
http://cgi.ebay.com/48-Red-Model-Rocket-Parachute-Quality-Rip-Stop-...
the description says 'slow descend' for 1.5kg and moderate speed descend with ~2kg...
my copter will be more than 2kg, so i think there's no chance i'll try some smaller than 48"....
on the same hand, i hope 48" will be enough...
http://vimeo.com/8904576
for sending 0% throttle i have to use the copter code, and at the moment of truth i rely on the electronics.
if the quad fails because of the electronics, i cant use the software to turn off the motors...
i must have an aggressive and simple way to switch to emergency state, like disconnecting the motors or the APM
you could also send 0% throttle to the ESCs instead of disconecting them.
With no signal, and ESC not having any failsafe function, should stop
Here i found a successful one, @ 0:40
https://www.youtube.com/watch?v=NbQryfscr-U
