PhotoSculpt vs PhotoModeler - 3D model test
FrankC on APLanding drew my attention to PhotoSculpt - a low cost 3D modelling programme - http://www.photosculpt.net/ - approx $150. I compared this with PhotoModeler Scanner - http://www.photomodeler.com - $2,695.
The results are shown in this crap video I made (too quickly) and clearly for this application PhotoModeler is superior - by far. But horses for courses....
  • Chad,
    friend request and message sent.
    Mike
  • Morli, there are many uses of detailed and accurate 3D information but the two main ones are kind iof connected. One is to assist in creating an orthopoto of a site - this is essentially a geometrically correct photograph that can be used to measure distances off - just like a map. The 3D info allows the mapping software to correct a point on a photograph to its correct geographical position in a mapping grid taking into account the distortion of its position in the photograph caused by the terrain.
    The second use is for engineering development of infrastructure and that usually requires the orthophoto and a 3D model that can be used for detailed planning looking at levels. Typical applications might be reservoirs, roads, river analysis....they are many and varied. These are applications that I might use the data for within my own field of interest which is civil engineering. There are others such as archaeology (the inspiration for AirPhoto) and a couple of guys here and on APLanding have more interests in those fields than I do.
    For actually flying a UAV these things are of no real interest whatsoever. My interest in UAVs is not in the aircraft itself but as a tool. Some people like weightlifting and spending a lot of time in the gyn for no real reason other than keeping in shape. I could only ever that effort when I had something to do that needed it - rock and ice climbing and other sports....if not for that I have no real interest in the gym! Same analogy...
    I am presently in Angola so have a very slow internet connection and could not view it but one of our fellow members has done some excelent work with Microsofts free 3D modelling and made a 3D model of that same slab which I think was much better than the PhotoSculpt result - and it was free! Unless you really need it though I would not waste too much time worrying about it.
    To be fair to PhotoSculpt it is not intended to do the same job as PhotoModeler and categorically spells that out. I just though it worth making the comparison to see what happens. I have made a few more pairs this afternoon and was similarly disappointed. Horses for courses...
  • Admin
    Got it Mike :-) , , thanks for explanation, Yes I was wondering about the big drop in the image( photosculpt) of what was solid block, the photomodeller video wasn't too good here for me to make any sense on what I was suppose to look for. So what would be obvious usage/advantage of such software in drone flying or Autopiloting or even RC/fpv flying ( I am a noob in photo/video processing) ?
  • Morli, you are missing the point of the test and I am not sure you read and understood my comment above. Let me spell it out:
    PhotoSculpt shows massive holes and bumps in the surface of what is a flat concrete slab and shows the slab as falling away from the drainage ditch - all of this is completely wrong!
    PhotoModeler - has made an excellent 3D model of the slab and even shows the gentle fall to the drainage channel. The fact that it is not a pretty image is because I didn't process it at a high density. PhotoModeler is so much more powerful in terms of output options and what it can produce. Also note that PhotoModeler requires a camera calibration and this is definitely going to improve the results. I tried some of the sample photos supplied with PhotoSculpt and again they did not give planar results when they were expected.
    Morli the PhotoModeler results are excellent - you need to look beyond the glamour! PhotoSculpt's results are very poor for this particluar application.
    Brakar, I certainly think PhotoModeler is an option, especially for smaller sites. The reason I did this test was to investigate its accuracy and reliability - it looks good. I took the pictures at angles that might represent those you might get at from an RC plane or heli. Others prefer Leica Photogrammetry Suite although I think that is more expensive, as is PCI Geomatics. I will be continuing with PhotoModeler as I was very happy with the results from the slab and am now looking for some other photos to test it with - as soon as I get my Gaui Quad!
    I have had a look at AirPhoto and if it is only 2D mosaics that are required I would suggest that it is a good option. I haven't tested it yet but we are in the process of doing that. It does not calculate DEMs or create 3D models although it will 'invent' them from spot heights you put in - not really good enough for what I am looking for. The AirPhoto website is appalling but the manual is excellent but rather long if you want to print it (418 pages!). It is not obvious but you have to pay for it - about Eur297.50. A friend has started to test it and found it 'buggy' and hasn't got far with it yet.
  • Admin
    Mike, are you suggesting us to go for photomodeller (2695 $ !!) even though the video is crappy & photosculpt (150$) looks better in video ?
  • Mike, do you think PhotoModeller is an option for use with aerial images?
  • Morli, exactly the opposite for serious purposes. The subject is a flat slab and PhotoSculpt produced the surface of the moon. PhotoModeler produced a very accurate model that even shows the slight fall of the slab towards the central drainange ditch. DOn't be fooled by the better graphic representation of PhotoSculpt - PhotoModeler can do the same - the test was to determine the capabilities of creating accurate 3D models not pretty ones!
  • Admin
    looks like commercial for photosculpt ;)
