Pixhawk + LDL-T Laser Distance Sensor Integration Guide: Altitude Hold, Landing & Obstacle Avoidance
Pixhawk Integration Guide: Optimizing Altitude Hold (10–15 m), Precision Landing, and Obstacle Avoidance Using LDL-T Laser Distance Sensor
Modern UAV missions require reliable altitude stability, safe autonomous landing, and accurate obstacle sensing. The LDL-T laser distance sensor offers millimeter-level precision and robust TTL serial output, making it ideal for Pixhawk-based drones running ArduPilot.
This guide provides a complete, engineering-ready setup including:
  • Stable 10–15 m altitude hold
  • Smooth and precise autonomous landing
  • Single-point forward obstacle detection
  • Wiring diagrams, parameter tables, and workflow charts
1. Why LDL-T Laser Distance Sensor is Ideal for UAV Height Control
The LDL-T provides:
  • Millimeter-level accuracy (mm resolution)
  • 30 m measurement range
  • TTL 3.3V UART interface
  • High measuring frequency (3–20 Hz depending on model)
Compared with barometer/GPS:
MethodProsCons
BarometerSimpleAffected by wind, ground effect
GPSGood for global navigationPoor low-altitude accuracy
LDL-T Laser Distance SensorBest precision, instant responseRequires clean FOV
Result:
Using LDL-T Laser Distance Sensor as primary altitude source below 15 m dramatically improves flight stability.
2. Wiring the LDL-T to Pixhawk (TTL 3.3V)
LDL-T PinPixhawk PinDescription
TXDRXSensor → FC
RXDTXFC → Sensor
GNDGNDCommon ground
VCC (3.3V)3.3VStable sensor power
⚠ Do NOT power the sensor with 5V.
3. Enable Continuous Measurement
Pixhawk requires continuous serial distance data.
Send the following command once at boot:
AA 00 00 20 00 01 00 04 25
Sensor output format:
AA 00 00 22 00 03 AABBCCDD 0101 CS
  • AABBCCDD = Distance in millimeters
  • 0101 = Signal quality
  • CS = Checksum
Pixhawk extracts bytes 6–9 as distance data.
4. Pixhawk Serial & Rangefinder Settings
4.1 Serial Port (SERIAL4 Example)
SERIAL4_PROTOCOL = 9SERIAL4_BAUD = 115
4.2 Rangefinder Configuration(RNGFND1)
ParameterRecommended ValuePurpose
RNGFND1_TYPE10Custom Serial
RNGFND1_MIN_CM50Valid from 0.5 m
RNGFND1_MAX_CM1500Max 15 m usable height
RNGFND1_SCALING0.1mm → cm conversion
RNGFND1_POS6Start byte of distance
RNGFND1_SIZE4Distance uses 4 bytes
5. EKF Fusion Settings for 10-15 m Altitude Hold
Enable LDL-T Laser Distance Sensor as height source:
EK3_SRC1_POSZ   = 2EK3_RNG_USE_HGT = 1EK3_RNG_MIN_HGT = 0.5EK3_RNG_MAX_HGT = 15
Benefits:
  • Rock-steady altitude hold
  • Zero drift
  • Perfect for industrial UAV missions
6. Optimizing Hovering at 10-15 m
Recommended LDL-T operating frequency:
  • 5–10 Hz altitude control
  • Up to 20 Hz for precision landing
Optional filtering:
RNGFND1_FILTER = 2
7. Precision Landing Optimization
LAND_SPEED40 cm/sSmooth landing
LAND_PREP_ALT200 cmStart landing sequence
LAND_FLARE_ALT30 cmFinal slow-down
Standard workflow:
  1. 15 m → GPS / barometer
  2. <15 m → Laser height control
  3. <3 m → High-precision descent
  4. <30 cm → Flare and soft landing
8. Forward Obstacle Detection
Mount LDL-T Laser Distance Sensor facing forward (optionally 5–10° down).
Example logic:
  • Distance < 2.5 m → Slow down
  • Distance < 1.2 m → Stop or Loiter
Useful for:
  • Indoor navigation
  • Warehouse shelving
  • Trees / poles / structures
9. Recommended Measuring Frequency
ScenarioFrequency
Altitude Hold5–10 Hz
Precision Landing10–20 Hz
Obstacle Detection10–20 Hz
10. Safety & Fallback Mechanisms
  1. Signal Quality Check
  2. Range Overflow Check(>15 m)
  3. Voltage Monitoring
  4. Ground Testing Before Flight
11. Flight Testing Procedure
StageWhat to Test
Bench TestVerify serial output & parsing
Hover TestEKF switching & stability at 10-15 m
Landing TestLAND_SPEED tuning
Obstacle TestStop/slow-down logic
By integrating LDL-T Laser Distance Sensor with Pixhawk and optimizing EKF, rangefinder parameters, and landing logic, UAV operators can achieve:
  • Highly stable altitude hold
  • Smooth and accurate autonomous landing
  • Reliable single-point obstacle detection
Ideal for industrial UAVs, robotics, warehouse automation, mapping drones, and AGV-UAV hybrid systems.
