We've been working hard to make MatrixPilot ever more modular, and to test this modularization, I thought it would be fun to build a LOGO-like mission planning language as a plug-in replacement for the existing waypoints module.
After a few evenings of playing, I ended up with something that actually feels pretty useful. All the logo basics are there: HOME, RT, LT, FD, BK, REPEAT, etc. You can also set specific locations (like traditional waypoints), set altitude, and set and toggle flags like whether to fly inverted. You can also toggle between controlling the plane, and controlling the camera target. More info on the language here.
The above image is from a simulation of the following UDB LOGO program running in XPlane using MatrixPilot's HIL Simulation.
// 10-pointed star with an external loop at each point
REPEAT(10)
// One leg of the star
FD(2000)
// Turn 180 + 72 degrees over the course of 18 small segments
REPEAT(18)
RT(14) // RT( (180+72)/18 )
FD(50)
END
END
Actually, we have very little data on what happens when the distance between Tx and Rx is large enough to degrade the pulses. I have thought about it, and done a little bit of testing with my Tx antenna down, and I don't think it would be pretty. The problem is there could be a large number of erroneous pulses coming through that would not be so far off as to trigger RTL.
Plus, I think that the range of a fully charged Tx might be way farther than you would want your plane to go, it might even be far enough to drain your battery, depending on the pattern you are running.
I think the far safer thing to do would be to put in an explicit distance range. Then, conservatives like me could set it for 200 meters, while the folks in countries that permit out of visual range flying could set it for as far as they want.
Best regards,
Bill
Trigger an automatic return to launch if the plane got farther away from the origin than a specified limit.
Best regards,
Bill
Same as everywhere, but with nested loops, you are practically OBLIGATED to do so in order to avoid surprises. You will see, once a number of parameters grows, you will be bound again to the laptop under the sun.
But I'm not willing to give up on nested repeats. They allow too much cool stuff. :) I'm thinking of making a quick and dirty tool to let you run a UDB Logo program on the desktop before a flight, to make sure it's planning to do what you think it is...
Therefore I have opted for allowing only a single loop in flexipilot.
