We're within a day or two of releasing ArduCopter 2.6.1 to the public in the Mission Planner. It's the best performing code we've flown and the waypoint accuracy is really impressive. You can check out Marco Robustini's video above to see an long-distance waypoint flight, some tight loiter at 5:30 (holding in a 1m box!) and a fun demo of autorotation.
A full list of changes is here, but they include:
Performance improvements:
- Better loiter, especially with the new 3DR uBlox GPS. Check out the video from Marco above!
- Better yaw control
- Better DCM implementation, resulting in noticeably smoother flight
- Better camera control, including improved setup in the Mission Planner.
- Etc
Bugfixes:
- Fix to dataflash erasing, which should resolve an issue some users were having
- Fix some MAVLink commands
- Fix Circle command
- Fix some units
- Etc
Tony: I don't think so, but I don't run the store. Email sales@3drobotics.com and ask.
Rana: That's just the standard new uBlox GPS from 3DR. It's the recommended module for ArduCopter.
Don't hold armed propellers next to your face like he's doing.
@Rana, just a simple language mistake.
Agreed, I don't see how this is autorotation. I think he was just using the term for fun? Autorotation requires the possibility of negative collective pitch. This allows the airflow through the rotor disk to actually speed up the rotors, like a maple-seed falling. So the copter almost free-falls, but maintaining rotor speed, until the last second when you pull up and dump the rotor inertia into thrust, which stops the descent.
I think he was just attempting to show the good stability in a fast descent, no wobbles.
@John, the motors absolutely stop in flight. I've done it, sort of a fun trick, to watch it tumble. Just make sure there are no trees nearby when you turn the motors on, because the stabilization routing causes it to rocket off in an unpredictable direction while it tries to come rightside up. :o
Marco said in the video, the waypoint is three thousand meters away, however it was 300mt ?
Another great video Marco!
In helicopter-land, an auto-rotation is an unpowered descent. So in a traditional helicopter if you lose main power, you can still land safely as long as you keep your main props from stalling (i.e. stopping). They act a bit like a parachute and you can maintain control.
I'm actually a little surprised that Marco's quad doesn't immediately flip when he reduces the power to throttle to zero. When I do that, my engines do stop and the quad tumbles..of course, as long as you have some altitude it's easy to recover..just give it some throttle and it recovers very quickly. Maybe Marco has his radio set so that his engines never completely stop until he disarms?
How such a nice GPS position accuracy achieved ? Is some special GPS used ?
Really what a great performance ! approaching toward the performance of DJI.
I do not think that it is autorotation that is demonstrated. Instead he is showing that arducopter will not stop the motors while in flight, even if you have zero throttle. The reason for this is that if you let the motors stop completely in a free fall they will indeed start to autorotate and spin the other way. And opposite rotation makes it hard for the ESC to start the motors again, resulting in a crash.
the props rotate automatically when in free fall, I don't understand why it was "demonstrated" as you only really hear about it when helis lose power in flight causing an auto-rotation. the problem I have and its a minor one is that we get no real good sense of scale on when he applies throttle and how close the quad is from the ground at its lowest point. I would be interested to find out what a decent safe autorotation landing height would be as thats valuable info in the case of battery failure or power loss at height
1
2
3
of 3 Next
