PX4 Bixler Chassis
3689509647?profile=original
This is my first contribution, is the PX4 Electronics Chassis for the Bixler based on the 3DR chassis (Images for the angles) and the files from Simon referred in this post, I modified the shape in order to make it geometric and added some holes in the structure to make it lighter, the electronics base is designed as a damping structure but the 2mm acrylic plastic (methacrylate) might be too stiff. I also added two supports for the Pitot Tube for the Air Speed sensor.
This are the parts after the laser cut, the dark dirt is a result of the heat from the laser, just used alcohol to clean it.
This is the assembled chassis, it contains the uBlox GPS, the Freescale Diff pressure sensor, the arming button and the buzzer for the PX4:
3689509960?profile=original
Now its time to start the development inside the PX4, so hopefully I'll be flying by the end of march.
This are the design files:
Chasis-MR.dxf
Chasis-MR.pdf
Unfortunately I have not test it on my Bixler since I have it in another place, feel free to comment and give me some (good xD) feedback.
I invite you to check an old but nice project I made when I was in my bachelor.
  • I just create a 3D printable version of this and post it on thingiverse (http://www.thingiverse.com/thing:1195608) if someone is interested in this.
    Logan
  • Would you be willing to sell me one of these? I don't have access to a cutter :(
  • Excelente aporte Miguel.
    Quiero comunicarme telefonicamente contigo.
    He comprado la Bixler 2 con fpv pero aun no la configuro. Podrias asesorarme al respecto o enviarme pasos, confirguraciones, etc.?
    Estoy en Cali. Mi numero es 3163443507. marino(a)gmx.es
    Me das tu numero por favor?. Te llamo Gracias.
  • Thanks Miguel.
  • Really nice work Miguel, looking great. Is there still space for the Lipo? You fix it on the plane with elastic bands?
  • Very nice!
    Of course this same 'chassis' could be employed with APM2.x with the appropriate drilling pattern.
    Build (and design) on!
    -=Doug
