Q Brain 4 x 20A Brushless Quadcopter ESC
36674.jpgThe Q-Brain incorporates 4x 20A speed controllers in 1 device. All motor leads are pre-installed and are terminated with 3.5mm bullet connectors. Leads are 25 cm long which means that you can use this controller with frames up to 60 cm. It operates on 2-4 cells lipo and 5-12 cells Ni-XX (anyone still using these). Refresh rate is over 400Hz.
Weight of the speed controller is 112 grams and dimensions are ~70x62x11 mm. The Q-Brain is probably very similar to the Hobbywing Quattro ESC.
Advantage: Easy install
Disadvantage: If one of the esc's dies you can't use it with a quadcopter anymore (get a tricopter!)
More information on the Hobbyking site
Note: If you are using the Q-Brain with a KK2 board, then S3 (the white cable) has to be connected to M1 on the KK2 to power it.
  • I am planning to install this Q Brain and APM2.6 on a a frame body for this frame below.
    Now my question is the order for the "sandwich" I am preparing, so, first APM2.6(internal compass), then Q Brain, then on top GPS, or Q Brain, APM, GPS.
    Any suggestion? Some metal plates between them to protect with compass and magnetic/electric interferences?
    I do not want yet the external compass, my actual quad fly good so far.
    Walkera QR X350 GPS Quadcopter - Body Set
  • silabs not atmel chips,not simonk but blheli.... google it.
  • Hey, since you'be taking this beaty apart coulf weight how much it weights without wires and without its enclousure? I among many other people would greatelly appreciate the effort!
    @Jed: I'm not sure I2C is going to give you speed you are expecting. PWM is quite effective at tranmisting a new value from the controller with good resolution, you update the motors every 2000us being parallel. I2C is serial, using 10bits per byte sent. 2bytes for each message for the same resolution. Then you have multiple devices on have same bus. All competing increasing latency of each control packet to the motors.
    But, I agree, in having a port like i2c, to get non time critical information back and to configure the speed control behavior would be awesome... I never remember how many beeps mean what :-(
  • OK, I have been wondering when somebody was going to make an all in one speed controller board. Now all they have to do is to put an full digital I2C connection on it and get rid of the PWM signal for speed control and gain current, voltage, and temperature status fed back from the board. (SIGH) Maybe Someday. . . .
  • Hi Robert, yes I noticed that after I put in the response, I also noticed that HobbyKing says that you can use their programmer with their version whereas no such option is listed for HobbyWing ones.
    Hard to find anybody not in China or Hong Kong that carries any of them unfortunately (even EBay is from China).
    I wish HobbyKing carried more of their multicopter stuff in their US warehouse.
  • If this is like skywalker quattro 20 than you can flash BLHELI. SimonK is for atmel. I realy like the sil-chip / blheli combo, anyways.
  • Gary, Hobbywing starte with a 20A, and continues to make the 20A.  The 25 Amp is relatively new, and not many people even carry them.
  • Seems they greatly reduce interference to the magnetometer, (No DC power leads except battery in and an aluminum plate on top attenuating AC EMF).
    Looks identical to Hobbywing except 20 amp instead of 25 amp. My guess is HobbyKing just derated it inline with their own real world experience.
    These are a real bargain and if you have a quad that operates within their specs it definitely seems like the best way to go.
  • I haven't tried it. From what I was reading at the time, it sounded like they wren't supported - may have to check again.
