This is a quick how-to to get going with ArduPilotMega QGroundControl Integration. Note that this is a work in progress and that the gains/ waypoints sent to the apm are not currently setting the values in the autopilot. I'll be working today to hook these up. I could really use help debugging and coding though so I've posted this to get everyone else up to speed.
  1. Get ArduPilotMega mavlink branch: svn checkout http://ardupilot-mega.googlecode.com/svn/ArduPilotMega/branches/mavlink "pathtosketchbook"/ArduPilotMega
  2. Get Arducopter libraries: svn checkout http://arducopter.googlecode.com/svn/trunk/libraries "pathtosketchbook"/libraries
  3. Get Mavlink: git clone https://github.com/pixhawk/mavlink.git "pathtosketchbook"/libraries/mavlink
  4. Get QGroundControl: http://qgroundcontrol.org/downloads or build from source: git clone https://github.com/pixhawk/qgroundcontrol.git "base directory"/qgroundcontrol, if you build from source you will need to copy "pathtosketchbook"/libraries/mavlink to "base directory" or create a symbolic link
  5. Set sketchbook path for arduino to "pathtosketchbook", then restart arduino IDE.
  6. Create an APM_Config.h file as seen below.
  7. Compile and upload code to board.
  8. Start QGroundControl, select network, add link, set to comm port (/dev/ttyUSB* on linux, COM* on windows) and then set the baud rate to 115200 (if using GCS_PORT 3)
Here is some documentation:
APM_Config.h file:
#define DEBUG_SUBSYSTEM 0
#define FLIGHT_MODE_CHANNEL 8
#define FLIGHT_MODE_1 AUTO
#define FLIGHT_MODE_2 RTL
#define FLIGHT_MODE_3 FLY_BY_WIRE_A
#define FLIGHT_MODE_4 FLY_BY_WIRE_B
#define FLIGHT_MODE_5 STABILIZE
#define FLIGHT_MODE_6 MANUAL
#define GCS_PROTOCOL GCS_PROTOCOL_MAVLINK
#define ENABLE_HIL ENABLED
#define GCS_PORT 3
#define GPS_PROTOCOL GPS_PROTOCOL_IMU
#define AIRSPEED_CRUISE 25
#define THROTTLE_FAILSAFE ENABLED
#define AIRSPEED_SENSOR ENABLED
  • James, Thanks a lot for your work on the integration with APM. I have used qgroundcontrol successfully to update parameters and do some other stuff but still have trouble with uploading waypoints (at least I suspect it's the GCS and not the APM causing problems). It seems that the altitude of waypoints (by default 0m) is absolute and not relative. Can you confirm that? I was wondering whether it's a bug or a feature :)
    The other issue I've had (but that's not related to APM integration) is that it does not seem to cache google map tiles. My 3g connection on the field is sporadic so it takes quite a few attempts and a lot of time to download tiles whereas it should be pretty simple to just cache these. Do you know if there is a way to activate this?
    This is all with Mac OS, APM 2.22, qgroundcontrol 0.9.0 (the dmg build). Thanks!
  • Thanks James, so the first step should be:
    1. Get ArduPilotMega mavlink branch: svn checkout http://ardupilot-mega.googlecode.com/svn/ArduPilotMega/trunk "pathtosketchbook"/ArduPilotMega
  • Thanks James i just got it working!
    Use the trunk, the mavlink branch is now obsolete since it has been merged with the trunk.
  • Hi,
    I followed the directions exactly, but every time i try and upload the code it gives me the error:
    " 'APM_ADC_HIL_Class' does not name a type"
    does anyone know what might be the issue?
    Thanks for the info Juan. I have been using it on my desktop at 115200 with the XBee 900 Mhz modules and it has been functional. I haven't flown everything in the field yet so maybe I'll run into this problem at longer ranges?
  • Sweet! Glad to hear there is Linux support for all this. As soon as I get a few flights in, I will start poking around and see if I can get all this setup. I am quite glad I am not the only nut who likes linux.
    The development team is pushing hard to have a new stable release soon. There have been some great flights on the beta branch but there are still a few kinks to work out.
    Sounds Great! I work exclusively on linux so you should be all set for HIL. I use the oooark scicoslab toolbox to talk mavlink to APM over Serial0 and then talk to qgroundcontrol on Serial3. http://oooark.git.sourceforge.net/git/gitweb-index.cgi
  • Awesome, thanks. I will keep an eye on the trunk. I just got my APM board a few days ago, and am developing under linux so I have no HIL. I will stay out of the main branch until I get a few flights under my belt. However, I hope to eventually help with development.
    Any chance another stable APM release will be coming out any time soon?
