QuadPlane support in APM:Plane 3.5.0
The upcoming 3.5.0 release of APM:Plane includes support for QuadPlane - a hybrid plane/multi-rotor that allows for high speed long distance flight with vertical takeoff and landing.
The above video shows a converted HobbyKing Firstar 2000 doing a fully autonomous mission, with VTOL takeoff, followed by automatic transition to fixed wing flight and then a VTOL landing. The planes builder, Jack Pittar from CanberraUAV, is shown with the plane below.
3689677459?profile=originalThe plane itself was fairly easy to build, with the simple additional of rectangular section aluminium arms on the Firstar wings and 4 quad motors.
One issue we found is that the battery we are using (a 3S 4Ah 65C) doesn't handle the 65A needed for vertical takeoff well, with the voltage dropping to 10V on takeoff. After takeoff completes and it transitions to fixed wing flight it quickly recovers. We will be changing the battery setup for future flights.
A second issue is that the wings tend to twist a bit in flight, especially when yaw is commanded. That greatly reduces yaw authority when hovering. We are still thinking about the best ways to prevent wing twist.
The new QuadPlane support is documented at http://plane.ardupilot.com/wiki/quadplane-support and is included in the 3.5.0beta1 release (I will do a separate blog post on that release shortly).
In the near future we expect to add support for other hybrid frame types, including tilt-rotors and fixed wing aircraft with other types of multi-rotor frames attached.
This QuadPlane follows on from our earlier Senior Telemaster QuadPlane which used two Pixhawk flight controllers.
scaled_IMG_20150830_093548.jpgWe built the Firstar QuadPlane to test the new code where a single flight controller board running APM:Plane is used, which makes for much simpler operation. We plan on now building a much larger version, with a 50cc petrol motor for fixed wing flight.
    @Antriksh, yes, most people flying quadplanes are using a Pixhawk or pixhawk compatible board
  • @Andrew
    Dose Pixhawk support Quadplane ?
    @Antriksh,
    The APM2.x doesn't support firmware 3.5.x, and doesn't support QuadPlanes. We stopped developing for the APM2 quite a while ago.
    You will need to get a more modern flight controller board to use the QuadPlane code, sorry.
    Cheers, Tridge
  • Hi
    This is so fascinating to me.So i prepared frame setup and installed APM2.5 from Rctimer. Installed Mission planner1.3.37 on my windows7.
    Uploaded APM plane3.5.3 firmware.
    Now i can't find Q-prefix modes and parameters in the mission planner.
    What did i miss?
    Plz help me out.
  • I am converting my Volantex Ranger into Quadplane. I would really like some help with Q_RT_RLL_P and Q_RT_PIT_P parameters. Can anyone please advise? Sander?
    Thanks,
    Jacques
    @Anthony, I've added the RATE message from copter plus a new QTUN message which has the fields from the copter CTUN message. That is in master now and will be in the 3.5.2 release which will be coming out shortly.
    Those messages should make analysis of quadplane logs a lot easier.
  • It was just the landing gear. I made the front legs shorter and now he is level when standing on the ground.
  • Ton, do you think perhaps the center of the quad motors isn't on the plane's CG? What else would cause it to appear tail heavy? Do the logs show the back motors working harder than the front? Sorry I can't see your logs now, I'm traveling.
  • @Iskess,
    No, we didn't install the quad rotors with forward tilt. Actually, the whole plane was tilted backwards (tail down) a few degrees and I think that might have caused the problem. On start up, the plane flies backwards a bit, corrects the attitude to fly level and then starts to go up. If that happens, combined with strong headwind, I think it causes the Pixhawk to go into a kind of failsafe mode and lands immediately. Not sure, and this is what I like to know.
  • @Anthony,
    I'm interested in your experience with the pitch of the plane. Did you install the quad motors with a forward tilt? Is this what gave you the trouble? How much tilt?
    Thanks.
